This problem is nothing to do with amount of current drawn from the RCR2.
The problem is spotted if you shake the RCR2 & you feel or here movement inside.
The Reason that we did not spot the ones that were DOA was because they were sold as extras & did not go into anything to test.
Now that we are aware of the problem (which is a manufacturing fault by the RCR2 Factory) all RCR2's are tested before posting.
However due to the nature of the problem the connections inside the cell may just about be connected at the test stage & any sort of knock may disconnect the insides & you end up with a useless RCR2!
The latest batch of RCR2 350 Ma Cells are proving not to have this problem.
AW the supplier to myself very kindly has replaced any faulty RCR2's direct to my customers, he also has sent extra RCR2's to myself to cover the ones that I have replaced.
Any body who has ever told us that there RCR2 is Dead has always been sent replacements with out the need to send the dead one back to us.
So all you need do is email myself
[email protected] or AW & if your RCR2 has a rattle it will be replaced FOC. :thanks:
