I'd like to know where I can get a 3-way or 4-way click switch, much like the 4-way switch in the Nuwai triple 1-watt and 3-watt lights:
https://www.candlepowerforums.com/index.php?posts/997119/
It has four contacts, C, 1, 2, and 3. I'm not certain, but I presume it works this way: first click connects C and 1; second click connects C and 1 and 2; third click connects all four; fourth click disconnects all.
My intent is to use such a switch to turn on and off a modded flashlight and control the dimmer function of a Fatman regulator. Fortunately in the Fatman, the POT(GND) and VIN-(GND) are electrically identical, which would allow me to use a switch like the one above to turn the light on, and give me two or three different brightness levels, by using a network of resistors. I would use a POT instead, but I can't think of a good place to put it and make it waterproof.
LEDhacks sells a 3-way switch, but it doesn't work in a way that I think I could exploit to turn my flashlight on and off and control the dimmer function: first click connects C to 1; second click turns off; third click connects C to 2; fourth click turns off.
