FifthLight
- Joined
- Sep 7, 2005
- Messages
- 7
Hello Everyone,
I found this forum and decided to go straight to the pros for the answers I'm looking for. I'll try to briefly explain what it is that I do and what I am looking for.
I work for a company that offers solutions for dimming office building lights. I am personally in charge of producing a sensor that will detect light levels (outside) for the system to use to dim/adjust the office lighting, nearest the windows, accordingly. The production of such a sensor is easy. The calibration of the sensor with the rest of the system is a little bit tricky.
I have to calibrate these sensors before they are installed using varying degrees false but consistant "sunlight" (ie. flashlight or spotlight). Basically, I'm looking for something that I can put right up against my light meter and sensors.
The idea is that I will simulate the light of a bright day (using my light meter to get the appropriate output) and then use that to get the output of my sensor at that light level. Then I'd repeat the same process with a cloudy day level, evening light level, direct sunlight level, indirect sunlight level, etc etc. By the end I would have a little table of how the sensor would react at varying levels. It would then be inserted into the software look up tables.
So I think you can see what it is that I'm looking for:
1. A flashlight that can dim and simulate various light levels with an adjustable switch of some sort. The closest I found to this was the Blackhawk Night-Ops but the problem is that it dims rather quickly making it really hard for me to control and repeat the process over and over. I would prefer a little more discrete control over the dimming.
OR
2. A simple bright light in unison with various degrees of tinted light filters (ie. tinted plastic). But does anyone know where I might be able to find such tinted pieces? I think there is a place here that can do such a thing but it would have to be custom job (thus time consuming) and there is no guarantee that it would be the correct tinting that I would need for each level.
Keep in mind that I am not against building something as long as its fairly portable. However, I would prefer to be able to grab something from off the shelf just to make things easier. Money is really not a concern here either.
Any suggestions? Other ideas?
Thanks!
Eric.
OR
Thanks!
Eric.
