The AccuManager 20 documentation says that it accepts a range from 12V to 16V DC. I did a quick test about an hour before sunset with the UniSolar flex 32 panel and a couple AAs and it appeared to be working fine – normal blinking lights – which is the charge indicator for this charger – steady when done/trickle. I then began to fold/shadow the panel to reduce the output and eventually got two different flashing/charger error conditions – which I assume indicated that the voltage was too low. I put a meter on the leads while everything was connected and got about 6V in the fully exposed very late afternoon sun - normally reads in the mid teens in full sun. The voltage was around 5V when the first abnormal/undocumented flashing occurred, and around 4V when the next condition kicked in. So it appears this charger works down to around 6V but I did not test the charge rate in that condition – all I'm going on is the indicator lights on the charger. The panel is not the Brunton panel but there is a good chance that the cells are similar – although this model is capable of supporting higher current loads than the Solaroll 4.5 – which could be the limiting factor. Weather permitting I'll try to do some more testing in the next or day two and see if I can mimic the performance of a smaller panel.
The charger itself is very nice and can handle one to four AAAs, AAs, Cs, or Ds, and one or two 9V – NiCad, NiMh, and RAM cells – smart charge followed by a trickle charge. The unit, without the wall wart, is very light and easy to hook up to a solar panel. It may be a little bulky for camping but the versatility is certainly a plus. I bought it about a year before it was reviewed on this site – I was glad to see other people liked it as well.
