Kilted
I have a Maha C777-II it is nice that a universial AC power supply and a 12 power adapter came with it. BUT I could not charge a string of 8-NiMH off of 12VDC inout.
Left over from my traveling days is a Targus car/airplane adapter. It has 12-24VDC input and 3-24VDC output depending on the power tip selected. I went thru the tip selection that came with the unit and found tip #24 had the highest voltage. It gave 17.7 volts on the lcd panel. I did check tip polarity first with a dvm.
I've charge two NiMH battery packs 8-AA 2500mah and 8-C 5000mah and it looks like it's working just fine.
I've emailed Targus if there is a 24vdc tip that I could use. No responce yet.
=D~~ Kilted
=D~~ Kilted
