Olight - S1 - MINI
Page 4 of 13 FirstFirst 1234567891011 ... LastLast
Results 91 to 120 of 373
Thread: 1kW Xenon Arc Tank Light
  1. #91
    Default Re: 1kW Xenon Arc Tank Light
    So... you got the small one?
    http://saturnsurplus.com/lights/search.htm
  2. #92
    Retired Account
    Dec 2001
    Wasilla, Alaska, \
    According to the Saturn Surplus they want $595 for that puppy, good price indeed!
    Here is two of them on Ebay at a $1,000 and $1,100
    http://i24.ebayimg.com/02/i/01/fb/d7/21_1.JPG
    http://cgi.ebay.com/Infrared-Searchl...QQcmdZViewItem
    http://i24.ebayimg.com/03/i/04/16/16/e4_1_b.JPG
    http://cgi.ebay.com/AN-VSS-1-V-2-INF...QQcmdZViewItem
  3. #93
    Jun 2003
    Portland Oregon
    100 amps at 28 volts = more than 1kw.
  4. #94
    Flashaholic* lotsalumens's Avatar
    Jan 2005
    NYC, USA
    Quote Originally Posted by markdi
    Mark,
    That's not the same light. The VSS-1 is MUCH bigger and heavier than the VSS-3 that I have. It also pulls close to 4kW. Interestingly the candlepower rating is the same, probably because its beam is not as tight.
    Couple more photos of my VSS-3
    cfb
    "It is better to light one multi-kilowatt xenon arc megalight than to curse the darkness."
  5. #95
    Nov 2005
    CT
    That looks a lot like the "Back to The Future" movie's Flux Capacitor.
  6. #96
    Jan 2005
    NYC, USA
    Doesn't it? The "Danger 50,000 volts" adds to the effect!
    cfb
  7. #97
    Does anyone know how this compares to the Spectrolab Nightsun SX-16? Just curious as I have seen its performance on Denver's helicopter. I imagine it would have to be fairly similar. This is the link: http://ils.spectrolab.com/default.aspx
    Sincerely, Jeffrey, Littleton, CO
    SF: E1e; E2d; G2; L4; 8AX; M3 (and KL6 LED conversion); M6; 10X
    Insight Technologies: M3 Inova: T4; X5 (UV); 24/7; Microlight (blue & green)
    SL: Stinger; UltraStinger; SL-20X; SL-35X; SL-20X-LED; Twin-Task 2D; Twin-Task 2-cell lithium; Stylus (UV); TLR-2 (Mounted on G21); Key-Mate (Black); TL-3
    Maglite: 4D; 3D; 2D; 2D-LED; Mini (2AA); Mini (2AA w/TerraLUX Ministar2 TLE-5 LED conversion); Solitaire (1AAA)
    XeVision: 75W HID BarnBurner
  8. #98
    Nov 2005
    NorthEast Tennessee
    tag
  9. #99
    Jan 2005
    NYC, USA
    Looks like the main difference between the SX-16 and the VSS-3 is the beamwidth and throw since they are designed for different kinds of use. The specs for the SX-16 say the beam diameter (maximum intensity not including spill) at 1km is 230 feet and the useful range for target identification is one mile. This makes sense for chasing suspects etc and it must really light up a decent sized area. The VSS-3 has a more collimated beam and is intended for target illumination at several miles for artillery. Documentation states that the beam can cause temporary flash blindness at 3000 meters (1.87 miles). Very neat technology in both lights!
    cfb
  10. #100
    Awesome! And, I'm sure the VSS-3 costs a lot less.
    Now I feel like I am getting a weak light when my BarnBurner arrives!
  11. #101
    *Flashaholic* KevinL's Avatar
    Jun 2004
    At World's End
    Quote Originally Posted by lotsalumens
    cfb
    Finally, a light where there won't be any whining "you can't temporarily disable an attacker with a light"
    Raising light to the level of a force option - 1kW at short range should cause more than just TEMPORARY disability.
    Celebrating the ROP.. 5 years of history
  12. #102
    Flashaholic Phased_Array's Avatar
    Mar 2005
    Hinsdale, IL, United States of America
    Lotsalumens,
    Where are all your cables?
    I finally scrounged up a mil-spec power supply.
    Did you ever wire up and use the remote control for your VSS3?
    I was starting to look for the connectors.
    Was wondering if the remote was useful to you at all, or if you had the connectors/cable for it.
    It's the cable with the '18-1 10 pin Amphenol' conns.
    Phased
  13. #103
    Unenlightened fixman88's Avatar
    Mar 2005
    sitting in front of my Widescreen Laptop
    Wow! That thing there is God's Penlight!
    Current EDCs: Maratac AA and Maratac AAA Stainless Steel
    Brony for Life!
  14. #104
    Jan 2005
    NYC, USA
    Phased Array,
    Yes I got the remote working last year. Needed it to get the light fully operational. The remote lets you switch to infrared mode as well as adjust the beamwidth of the light. It also has a bunch of circuit test functions. There is also a secondary smaller remote with fewer functions (all redundant) presumably for the tank commander to use.
    I gave my cable set to a good friend of mine last halloween for his light, so now I have to make myself another set (ugh...lots of soldering!). The light is currently in storage for the winter, so this spring I'll make the cables and hopefully have a bunch more beamshots by June when we are out there again. I want to get some shots showing the beam hitting a distant target. Just have to figure out where to do this I need a whole lot of open space.
    CfB
  15. #105
    WOOOOOW !! dude that is a NICE BEAM SHOOT !!!
    But... when you got to heaven, GOD will say "DAMN YOU ARE THAT DUDE THAT DID BLIND ME WHILE I WAS DRIVING MY UNICORN"
    And then your going stright to hell......
    http://www.photonlexicon.com
  16. #106
    * The Arctic Moderator * Sigman's Avatar
    Sep 2002
    "The 49th State"
    How the heck did I miss this thread?!
    I am truly humbled! We aren't worthy!!!
    AMAZING!!
    -"Must control self"-
  17. #107
    Flashaholic* RAF_Groundcrew's Avatar
    Jul 2005
    St Andrews, Scotland, United Kingdom.
    Quote Originally Posted by LuxLuthor
    It could work like a 'flux cpacitor'..... touch the wrong thing in there, and you're History
    If it wasn't for the shipping to the UK, I'd be looking for one !
    Do something, or do nothing, but do it quickly, there's a line forming !!
    ______________________________________
    Nigel Whitaker - Performing random acts of aircraft engineering. My Photo Site
    G2z, 9P, 6P, L1, 8AX, 8NX, M3, M4, M6, Jil CR2 DD, C2 with SW02 Nice !..... ARC LSH-S, ARC AAA-P, THOR 10MCP, and Illuminated PC Keyboard. Z3_FOR_SALE
  18. #108
    Enlightened CarbonArc's Avatar
    Nov 2005
    Salfordville PA
  19. #109
    too heavy&large to me...
  20. #110
    Mar 2005
    And don't forget, we military xenon 'Tank Light' guys got Connie Rod to go to for 'technical assistance'.
    Lotsalumens, check this PS out before powering up again!
    Phased Array
  21. #111
    Sep 2005
    Bloomington, Minnesota
    Wow, I spotted that very issue on eBay and bought it! I ran those same pages throught a copy machine and mailed them to lotsalumens. It was in B&W, now he can see Connie's outfit in color! My favorite line is "Operators and crew members don't mess with the window latch".
  22. #112
    Jan 2005
    NYC, USA
    Thanks guys for both the xerox and scan!!
    cfb
  23. #113
    I thought I would join in the fun and get one. I also have the manual and schematics if needed. I am looking for a power source, and will likely disable the IR mode. I also have a 16" diameter SS tube which I will transfer the internal two when I get running.
  24. #114
    Jan 2005
    NYC, USA
    Hi Tony,
    Did you buy a VSS-3 or one of the VSS-1's being sold by peakbeam?
    cfb
  25. #115
    No A vss-3. The vss-1 is way large, and not as collmiated. I will likly be solicting help in getting in running, I'am a ChemE and never been great with electrical. I do have a new bulb installed and the schematics look straight forward. As you suggested on/off is really my only concern although the motor controls for focus do look like fun to play with. One of my litigator friends thinks me insane and past along several engineer jokes. My favorite is the engineer that comes upon a taking frog. The frog states that If you kiss me I will become a beautiful Princess. The engineer says fine and sticks the frog in his pocket. The frog cries out if you kiss me I will spent a week with you. The engineer takes the frog from his pocket looks and smiles and places the frog back into his pocket. The frog cries out again I will stay with you for a week and do what ever you like. The engineer again removes the frog and tells her, Hey I don't have time for a girl friend, but a talking frog is Kool. He then returns the frog to his pocket. At any rate I owe my friend for her "wit" and as such want to get this working so I can peel Paint off her house.
    Thanks
  26. #116
    Jan 2005
    NYC, USA
    Well you've definitely come to the right place since there are a bunch of us with these lights. ShortArc is using a modular rectifier unit to power his VSS-1, so something like that could be an option. There are some Lucent 364B2 units rated at 100 amps and 29 volts which look promising:
    http://search.ebay.com/ws/search/Sal...fcl=3&frpp=200
    Might need some modifying for this use, but it could be a possibility. Haven't tried one myself. I know that the turn-on surge on my VSS-3 tends to trip the 75 amp breaker on my supply frequently, so a bit of excess current capability would be good.
    cfb
  27. #117
    Jan 2005
    NYC, USA
    P.S. Can you tell me where you got the new bulb from? It's always good to have a spare.
  28. #118
    Mar 2005
    These bulbs are still for sale at $300. It's a mfg. who was bought by another mfg, and once again. Used in theatre lights currently too. New in box mil surplus? maybe at some point, $75 for the AN/VSS1's.
    TONYD,
    Let me know if you hotwire it up successfully, I'm missing the control box and we need to shoot a lot of joules(Marx Circuit in cb) into the lamp to get those 40,000 volts.
  29. #119
    Mine came with the new lamp, so I have to research where it came from. I will contact the seller. Thanks for the offers as I also do not have the control box. I was also curiuos if a simple 24 volt truck battery charger would work. Several charge at 50-60 Amps in 24 volt mode. The manual claims 58 amps max for this light although, as has been ststed it pulls more juice. How are you geater 100 volts to the ignitor?
    Also I thought one thing about this light is the use of silver wire- I have cardis silver in my vacuum tube amp, but a giant flashlight? Just like a talking frog Kool.
  30. #120
    Flashaholic* ZeissOEM2's Avatar
    Jan 2005
    Norway
    edit
