ArmyTek
Results 1 to 5 of 5
Thread: in-place survival rather than bugging out
    Nov 2004
    DFW, TX
    Default in-place survival rather than bugging out
    In the event of a natural disaster or whatever- my thoughts have been that for where I live it is more likely that I should stay in my home rather than bugging out. So for a person contemplating staying in their home for a period of time without outside services, what supplies and plans are needed for survival?
    Food? (what kind and how much)
    Water? (how is the best way to do this)
    Fuel?
    Power?
    Communications?
    I would expect that besides our discussion here, people can provide links to similar discussions elsewhere, and I welcome that too.
    And another question- how much time should a person plan for?
    Pel. M6 LED, SL TL-2 LED, TL-3 Xenon, Scorpion, Inova X5, SharperImage Luxeon, Gerber Infinity, Petzl Tikka, 2C Mag 3x123 KPR112, 2D Mag 7xAA KPR118, Nuwai QIII, TM115, TM311, 3rd_shift Luxeon 3C Magmod, Solitaire Luxeon, MiniMag MJLED,Mag85, MagLed 2D.
    Flashaholic* Malpaso's Avatar
    Feb 2005
    MA
    Default Re: in-place survival rather than bugging out
    I have found that a large marine battery with a power inverter can serve numerous functions. I trickle charge mine once a month.
    It's not that life is so short, it's that you're dead for so long.
    Flashaholic* zespectre's Avatar
    May 2005
    Shenandoah Valley
    Jeez I'm going to sound like some nut-case survivalist, but I've been through a serious flood that completely screwed things up for the better part of three weeks. Our farm (where I grew up) wasn't hit that hard (except for the loss of power/services for the whole time) but when people who had lost everything showed up it got...interesting.
    Basic "shelter in place" priorities are as follows.
    Shelter - You need a viable place to stay, one that won't increase your risk.
    Sanitation - You are going to need a way/place to urinate/defocate (usually at least twice a day). If the power is out (and water, etc) you won't have a flush toilet for long. A large bucket lined with heavy lawn/garden type trashbags that can be removed and disposed of as filled is often a good basic measure). You will need someplace to dispose of the bags as they fill. A lid and Baby powder to sprinkle in to help with odor is also a good idea. A lot of other personal cleansing can be somewhat relaxed but HANDWASHING is critical to avoiding illness during these sorts of emergencies. If water will be tight, have some baby wipes and/or waterless sanitizer available.
    Water - You generally can't stay functional for more than three days without water. Rule of thumb is 1 gallon of drinking water per person, per day. (washing and cooking water is not included in this).
    Food - Start with your perishables first (cook up what's in the fridge first) and then move on to your canned and dry goods. You should have a weeks worth of regular meals on hand. Rationed out, most Americans could stretch that one week of food out to two weeks easily. Consult backpacking sites for all manner of recepies and the equipment to cook them with. Proper ventilation is ESSENTIAL for using backpacking stoves, if you have a balcony or some outdoors place to cook then do it there or you could quickly wind up sick or DEAD!
    First Aid - If you are sheltering in place in your own home then you probably have everything already.
    Lights - Have an assortment of lights, and extra batteries for all. If you have candles and lanterns use them, but use them very carefully. A lot of people have burned themselves out while "sheltering in place".
    Power - If you have a generator try to be stealthy with it. Run it as little as possible, during the day if possible, guard it while it is running, and lock it away securely when it isn't being used.
    Be Prepared to eventually offer support/shelter/food/water and so forth to a few other, less prepared, people (who might even be your neighbors or friends), or be prepared to defend you and yours against them if things drag out because starving people won't care about your friendship or your family, just food.
    ABOVE ALL - Be subtle about your preparations and stealthy when enacting them. If you have food/water, etc. and your neighbors don't, someone is bound to try and take it away from you (especially if they haven't eaten in 1-2 days and are getting hungry). Keep your lighting and so forth to an absolute minimum as a well lit place is a neon sign saying "we have supplies" and will attract all types.
    A note about weapons - If you are afraid to use a deadly weapon then don't have one 'cause some more desperate person will take yours, kill you with it, and take all your stuff! If you are reluctant to use deadly force you had better find an alternative.
    "Notorious collector of things that glow, shine, or blink"
    CPF # 9435
    Jul 2003
    Louisiana
    If you'd need all of that stuff to stay, you'd be better off bugging out. All of the stuff that you are looking to get would serve nicely if you didn't have a choice.
    Tony
    I do all sorts for Surefire mods and builds...Chop's Mods
    Nov 2003
    Kansas, USA
    In the case of air borne contanaments you will need plastic to seal doors, and windows, as well as air conditioning vents. This of course will limit your supply of oxygen. If it is possible to pick up an oxygen bottle or 2 from a welding supply, and keep in the sealed room this will afford you air of enough quality to breathe. Also by cracking the valve you create a higher air pressure inside the sealed room than is outside. This prevents outside air borne elements from comming in.
    "LIFE………….is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming - WOW - What A Ride!" #3475
