Inova microlight problem
srvctec
Central USA
I just got an Inova Microlight w/white LED from the local Target today (for 7 bucks) and picked out the brightest and best beam out of all they had. About 2 hours after I got it I turned it on and nothing happened (worked fine right out of the package). Come to find out the LED came loose and wasn't making contact (the LED can't come out because of the way the case is molded). I just shoved it in and then it worked fine. Has anyone else had this problem? Just wondering if this is a known problem with these lights.
I think I'll just ever so slightly bend the leads so they will wedge in their respective contact holes a little better. One plus to the loose LED- if I just shake my keys a few seconds, the LED comes out of the socket and I don't have to worry about accidently turning the light on when it's in my pocket.:ironic:
It appears the LED leads are about 2mm too short or that the sockets just don't hold tight enough. I may just put a small o-ring around the LED right above the ridge to allow the case to hold it in place properly.
I don't want to take it back for exchange- it was the best one they had- beamwise anyway!
Signs of a true flashaholic!- make it work if the beam was the pick of the lot.
Big_Ed
Sycamore, Illinois
I had exactly the same problem with mine. I just pushed the LED back in, and it worked again. I haven't yet bent the leads, but I plan to. I like the Microlight.
jar3ds
USA
humm.... very interesting.... so just to get a better picture of whats going on... is the LED coming straight out of the casing itself? or is it just getting loose?
since i put a red LED from the old model in my light.... the leads on that LED are a little shorter than the factory LED.... so i was a bit concered with it... but the LED fired right up...
this morning i was giving the inova the run through... i was throwing it on carpet etc... the first throw to the carpet at a relitive velocity opened up inova throw the batteries and the top cover everywhere.... however... the LED was still in there...
The led in mine almost locks into its place..... even after i throw it... i put the batteries back in and turned it on (w/o touching the LED) and it fired right up...
my LED is sort of hard to pull out... i alomst have to lift it slightly up.... and out...
prof
Western TN
I've also had this happen. Pushing the led back in seems to fix it, but be careful when opening the case to change batteries or look inside! The LED fell out onto the floor. I found it and put it back in with no problems.
Good light, good price, but this is an irritating issue.
BIGIRON
South Texas
A small dot of rtv silicone should fix it and still be fairly easy to remove if necessary.
srvctec
Central USA
The LED isn't actually coming straight "out of the casing" but just getting loose by coming out of the holes that hold the LED. It seems as though the leads are too small or the contact holes are too big or the leads aren't long enough to get down into the holes far enough for a good grip. When I shove it in, there is a little resistance, but not much. All it takes to loosen up the LED is for me to shake my keys for a few seconds. The LED will actually come clear out of the contact holes only to be stopped by the case catching the ridge around the base of the LED- thank heavens!
I'll probably either use silicone as suggested or a small o-ring around the base of the LED just above ridge which will also keep it in place.
jar3ds
USA
SRVCTEC...
let us know if either of those TWO methods fix your issue. Thanks for your input!
srvctec
Central USA
I tried an 0-ring to hold the LED in place, but it was way too fat.
I have an idea what the problem is, or at least part of the problem. Below is a close-up pic of where the LED goes. The groove is supposed to help hold the LED in place.
With the cover off, if I hold the LED down while trying to pull it out, it won't move past the groove. I don't think they made the cover fit close enough to the LED which would have held it in the groove.
I may wind up putting something on the inside of the cover to hold the LED down in the groove- this way I won't have to try the silicone.
LowBat
San Jose, CA
I see Inova microlight has gold contacts which I don't think the previous microlight had.
BlackDecker
Okla, USA
I have the previous model of Inova Microlight, and it is of much higher quality. The seams on the previous model fit very snugly. I bought the new style yesterday at Target, and immediately noticed the seams have slight gaps and the unit doesn't have the same 'solid' feel of the older one.
The high/low/flash switch is nice, but not at the cost of fit & finish.
attowatt
New Mexico
Could it be held snug with a piece of rubber , say3 mm from a rubberband, cut to the desired length? Just a thought.
Jim
Manzerick
Boston, Massachusetts
Would it work to fabricate part of the case with some "cold steel" type product? If a small about was fixed to the case it may help. Not sure of the effects on the bulb (if any)
srvctec
Central USA
Jim
I thought about trying something similar to that. I have some thin (about 1mm thick) sheets of rubber with adhesive on one side. I was going to try it until I noticed the gap between the LED and the case is less than 1mm.
I'm going to wrap some aluminum tape around the LED to eliminate the glare coming out of the sides and into the translucent case. I already have painted the rear of the LED with silver paint to eliminate the light going out the rear. I may just make an extra round or two with this tape and it'll be enough for the case to securely clamp the LED in place.
I'll post results when I have done this, hopefully tonight.
srvctec
Central USA
GOT IT PERMANENTLY FIXED!!:twothumbs
I put about 2 1/2 turns of the aluminum tape around the LED and installed it in the case. This took care of the problem. The case now clamps the LED tightly without any gaps in the case seam. See the first pic- you can see an indention in the aluminum tape about 1.5mm wide near the top of the LED- this where the case clamped down.
The bottom pic is with the LED w/aluminum tape installed in light. This pretty much took care of all of the light that was refracting all through the transluscent case (as you can tell, I don't like this). As I said before, I also painted the rear of the LED silver as well as the ridge at the base of the LED with a paint pen.
This aluminum tape is available at most hardware stores and is for sealing ductwork. I even saw a roll of it at Wal-Mart last night- I think it was 3M brand.
Donald
Miami, FL USA
I tried comparing the beam quality, but it was rather difficult considering the packaging. What did you look for? I tried to pick a couple of the nicer ones, but was not sure what I was looking for. Obviously I looked for a smooth beam, but with it cut in half and relecting off the plastic, I am not sure I suceeded. I also noticed that some appeared bluer than others, but the less blue ones seemed to have an off color, so I went with bluer versus white/green/yellow or whatever it seemed to be. Perhaps with some guidance I'll be able to make a better evaluation.
I am happy with the one I bought and opened, but I would like to know what factors you considered in evaluating the various packages. I'll keep your fix in mind, if I have trouble with the LED. :)
My old Inova had apparently turned on and killed the batteries, but it turns out it might be that the conacting membrane end had come lose and caused the problem. In any event new batteries were of no help and I then figured out what that little piece of glue or plastic was that was on the lid and fell out when I opened it.
Good excuse to get a light I find brighter and better. It says up to 15 hours use, I presume in low. Anyone have an idea what the reasonable run-time expectation is for decent light, as opposed to better than nothing at all?
I did want to point out, keep the clips from your old light. They are thicker stock than the new ones, so are more secure. My old clip is now on my new light.
Donald
Miami, FL USA
Thanks.
I did notice some were still in signal mode and thus presumably less used. I think I still ended up picking one that was no longer in signal mode along with some that were still in shipping mode. I did find a couple that seemed less blue tinged, but not necessarily for the better. It could just be they had been tried more--I believe those were ones no longer in the shipping signal mode. They did not seem as bright.
Still looking for the River Rock lantern which apparently they have not gotten here, if the sales person that I spoke with is correct...once she figured out I was asking about flashlights when I said River Rock brand. Noticed my local Target has the blue and green Inova microlights, but are now out of white. No 2 x AAA RR either.
cuervo
NC
On a slightly different line, has anyone had a problem with their keys turning the light on?
Whenever I pull my keys out of my pocket, the light is on.
I've tried different locations on the ring and different rings of different lengths with no difference.
