polished reflector infinity ultra
davidefromitaly
43.66 N - 13.13 E
i just have polished the reflector of my infinity ultra... well the result is very good
the brightest point pass from 92 to 98 lux with a lithium batt but what is more important is the total output: now the hot spot is sorrounded by a big and bright corona with a diameter around 3 times the original spot.
i estimate a 30% of more total output
very good :)
lrp
Wow! How did you polish the reflector? Thanks!
davidefromitaly
43.66 N - 13.13 E
well... first of all you must take out the led for not damage it
then i put the head on my little lathe and with abrhasive paper i take out the anodization
then i polished the surface with the tools that i use for polish the steel case of watches... if you don't have this tools i think you can try with a dremel
OddOne
I was thinking about doing this to my Infinity Ultra. I already have the gear to do it - a lathe, some 600 and 1500 grit sandpaper, and a can of Brasso to put a shine on it. (Brasso isn't suggested for aluminum because it makes it tarnish ultraquickly while you polish, but if you follow up with a solvent to remove the Brasso you get excellent results.)
oO
RA40
So. Cal
How difficult is it to remove the LED assembly?
I was playing with the original last night and pondered about polishing it.
RA40
So. Cal
greenLED said:
depends on whether you have the "old" or "new" version of the Infinity. Which one do you have?
I've got the old non-ultra.
liteboy
NYC
I just bought a Gerber IU and was unimpressed. The peak matterhorn 1led seems to produce equal if not better light. I will try a Photon freedoom soon since my brother's cheapo knockoff produced better and brighter light than the IU. disappointing especialy given how large it is.
