Sigman said:It would indeed be a SUPER WINNER with a flood beam!!
nemul said:how do you get the head off? pry or punch?
Here it is!nemul said:hmmmm, i've heard of that around here.... guess i'll try! wish me luck!
Where's milky and his write-up?Solstice said:Forget the CS; Milkyspit has a luxeon mod that would SMOKE any 5mm LED. The best thing about it is that the "spot" is doubled in diameter, while still being throwy.
Thanks Solstice!Solstice said:I haven't seen him on the forums much lately; I'm not sure he ever did a write up- I saw the mod in person at his house at Photon Fest 3. Scott is a nice guy, I'm sure if you PM him he'd tell you about it.
Flying Turtle said:I've had one for some time now. Still haven't figured out a good use, as it is rather specialized. You can get some flood out of it by putting tape or some other diffuser over the lens. Also, as someone long ago pointed out, just placing a finger in front of the lens can add some usability to the beam. I still consider its overall design almost a work of art.
Geoff
A word of caution on that. Friend of mine had his one on his belt and lost it. Once the little sheath is used a while, it can get loose and the smooth profile of the X1 makes it liable to slip out.Geddinight said:...I've had it on my belt for two days now, and it's a great size.
