Fenix Outfitters
Page 1 of 6 123456 LastLast
Results 1 to 30 of 168
Thread: Thread and O-Ring lubrication
    Default O Ring Lubrication
    My PT 40 is making a squeaking noise when I rotate the head assembly. What type of lubricant should I use? I hear that the wrong type will eat up the o ring material.
    Thanks
    Flashaholic* voodoogreg's Avatar
    Apr 2003
    Global
    Default Re: O Ring Lubrication
    first thing, make sure the lube is all around the ring take it out then lube it inside and outside so it's lubed on both surface's when you install it. sometimes if the ring is is not lubed on the body side it will squeak. VDG
    "In nomine Patris, et Filii, et Spiritus Sancti."
    "lumen Gentium!"
    I think nyogel is safe to use. I use it on all of my flashlights with no problem. Lighthound.com sells it.
    Lisa
    I'm using "MOLYKOTE 111" from Dow Corning.
    www.molykote.com
    Flashaholic* TORCH_BOY's Avatar
    Jan 2004
    Australia, Vic
    I have always used silicone gel, works ok haven't ruined any "o" rings as yet
    *Flashaholic*
    Dec 2003
    USA
    which lube is not really critical for most orings unless you cannnot get at the orings in question.
    best example is Surefire U2's selector oring which is non-user removable. some U2 level selector rings were extremely stiff and needed some lube.
    Nyogel 959G was exact lube used by Surefire for U2. slowly work some lube into slector assembly and body's heat will cause lube to migrate.
    highly recommend nyogel 959G, a small tub will last you forever and it will solve switch contact issues like krolls.
    Flashaholic* yaesumofo's Avatar
    Jul 2003
    Eastern Pacific, LAX DM03 sw actual
    Wink Re: O Ring Lubrication
    NyoGel 779ZC is what I use for all O-Rings and flashlights that don't need conductivity.
    NyoGel 759G for the threads and 779ZC for the O-rings. For most aluminum surefires this should work fine.
    I hope this is legal on the board.
    Go to:
    http://www.lighthound.com/sales/nyog..._lubricant.php
    It is funny this topic has poped up in a few places. I have just finished research on the topic and this is what I was able to find. I have been cleaning and lubing ALL of my lights for the past couple of days. The maintence adds up when your collection grows. Use good lube protect your investment.
    Have fun.
    Yaesumofo
    Support your local flashlight builder.
    Buy American. Stop crying and start Buying.
    Flashlights are tools. Period.
    Flashaholic* nethiker's Avatar
    Dec 2004
    Montana, USA
    How do you know which lights require conductivity? Could you just use a conductive lube for all lights whether they need it or not? Why do you use one lube for the o-rings and another for the threads.
    Thanks,
    Greg
    Jul 2003
    The non conductive is a bit more viscous it sticks better to the o-rings.
    The mcluxIIIpd and HDS EDC lights do not need conductivity in the lube. Surefire, ORB, ARC all do a bit better with the conductive lube.
    As far as I am concerned none of this is set in stone. There are MANY lubrication compounds, They all have different properties. go ahead and experiment away it is unlikely that you wil hurt your light.
    Yaesumofo
    Quote Originally Posted by nethiker
    Thanks,
    Greg
    Dec 2004
    Montana, USA
    Thanks Yaesumofo.
    Flashaholic* Haz's Avatar
    Apr 2005
    Sydney, Australia
    I have been using Silicon Grease Molykote 111 as well. It is pretty good for my needs, however I find the viscosity is rather thick. It is thicker than Petroleum Jelly which i use to use, however after reading post in the forums here, have been hesitant to use again.
    Haz
    Flashaholic* Anglepoise's Avatar
    Nov 2004
    Pacific Northwest
    The best lubricant for the PD is a 100% Teflon light grease.
    Nygel is too sticky and is unnecessary as the PD threads do not conduct current.
    Until you have used a teflon lube you do not know what smooth is.
    Available from these guys in a great dispenser Link
    David............................................." Some Homemade Creations"
    Flashaholic* Trashman's Avatar
    Mar 2005
    Covina, California
    I gotta get me some of that Nyogel stuff. About why sometimes conduct lubricant is prefered.....in some lights, the negative contact is made through the threads, others make contact at the base of the body (end face). An example would be the Minimag and Mag D. Minimag - contact through threads in on tail cap and body, Mag D - contact through the bottom end (face) of body and small "step" on tail cap that makes contact with the bottom of the body. On the Mags, the contacts are easily identified because they are not anodized.
    Apr 2003
    Global
    One thing to think about, is on light's that you have to screw one part into another agaisnt a battery or resistive bumper, like a o-ring or foam pad, after a few times of that you have eliminated a great deal of the lube put on the threads because as the thread meet's the resistence no longer will it stay "centered" moving the "needle" as it would against one side of the "groove" of the thread and chasing out the lube from first one side, then the other.
    (i have tested this myself outta curiousity with a strong mag scope to see how and if it migrate's, it does, and with much less use then one would think)
    I find considerably better and visable results by using a conductive film like caig product's that will form a harder layer and take more time to loose there effectiveness.and since it's a strong film you can lube over it and still gain most of it's affect.(imho of course) VDG
    "lumen Gentium!"
    Apr 2003
    Global
    Quote Originally Posted by Anglepoise
    My experiance with telon on metal surface's on race engines sure does give credance to anglepoise' ""remark Until you have used a teflon lube you do not know what smooth is.""
    Just one very important caveat, DO NOT use it on surfaces that do have signal teflon is a b***h to get off and will reduce or possably prevent conductivity.
    Other then that it kills!! I saw at the Mugen tech center in Europe (F1 engines) a piston
    placed in a cylinder with just thin race oil and not move. they applied there proprietary teflon formula on another, and it liturally FELL through the block! VDG
    "lumen Gentium!"
    Jun 2005
    Maryland
    I was told by a PT rep that a "Silicone" based grease, NOT spray is what you should use. WD 40 and other lubricants will eat the O ring up.
    You don't know the power of the dark side! That's why I need lights!!!!!!
    Flashaholic mykall's Avatar
    Jan 2005
    Williamsburg, Va.
    I've been using RS lube gel. It's reasonably priced, you get
    an entire tube for about $3.00.
    Don't know about other manufacturers but M_g recommends
    just plain petroleum jelly on their lights.
    MB
    Flashaholic Geogecko's Avatar
    Dec 2004
    Oklahoma, USA
    My question here, is what do you people use to remove the old lube? Do you just wipe it off with a rag, or use some chemical to remove it? I bought some Caig DeoxIT for this purpose, but not sure it's the best solution. I plan on using the NyoGel stuff on my SF lights.
    Mar 2005
    Covina, California
    Quote Originally Posted by DarthLumen
    What about silicone spray?
    Jan 2005
    San Francisco
    Default Simple Lubrication Answer
    Hi all. I know there are several posts out there discussing Nyogel this or Silicone grease that, and conductive vs nonconductive and grease vs spray etc, etc, etc. I've looked for "Silicone grease" in a hardware store and the guy didn't know what I was talking about. When I told him I was looking for something to lubricate the threads of a flashlight, he recomended 3 in 1 oil, which I used on a light resulting in it forming a hard compound with the coating on the inside (and is probably melting the o-ring). What I would really like is for someone to just tell me ONE GOOD PRODUCT and where to find it so I can slather it on my threads AND o-rings to keep all my twisty switch lights working properly for years.
    Sorry if this sounded like a rant , I just wouldn't have thought something as simple as lube would be so complicated. There's so many products people throw into the mix that I wonder if we need to start a lubricationoptionforums.com
    Thanks in advance,
    Jon
    *Flashaholic* KevinL's Avatar
    Jun 2004
    At World's End
    Default Re: Simple Lubrication Answer
    Celebrating the ROP.. 5 years of history
    Nov 2004
    Pacific Northwest
    For a one product only solution, I second that suggestion of Nyogel 759g
    Flashaholic* elgarak's Avatar
    Jul 2004
    Florida
    Gunk's Plumber's Silicone grease, which you should be able to get at any automotive/home improvement/hardware store. It's a pure silicone grease (no problems on O-rings). It's non-conductive, so you have to keep contact areas clean (which for me was a problem only on Inova lights, so far). Easy to get, and until now the only stuff I used on all flashlights. Though I might switch to Nyogel 759g, now that I found a good source (lighthound, formerly known as surefireparts).
    Sep 2004
    Toronto, Can
    Grinser2 Re: Simple Lubrication Answer
    You might want to slide over to this grease group buy...
    http://www.candlepowerforums.com/vb/...ad.php?t=91920
    Dec 2002
    Tennessee., USA
    Silicone grease is in the plumbing section of Lowes/Home Depot.
    The brand I see mostly is Plumbmaster; comes in a little grey tub.
    Flashaholic* RAF_Groundcrew's Avatar
    Jul 2005
    St Andrews, Scotland, United Kingdom.
    Buttrock Re: Simple Lubrication Answer
    I use silicone grease (white molykote I think), on the O rings, but I find it 'rough' when used on the threads, so I use Teflon based grease on the threads, and it gives a very smooth result. O rings are cheap, they will eventually get damaged (I'm an aircraft engineer, and we always replace O rings with new seals every time we dismantle, the price of failure is much more than a few pence for an O ring). Lighthound sells many sizes of O rings, spares cost mere cents.
    One point I would make, is unless using the standard tailcaps on Surefire lights (including LOTC, but not clickies), then maybe conductive grease helps, but with clickies, the act of screwing home the cap makes a solid metal to metal contact with the rear of the body tube, cutting through the layer of grease at the tiny contact points, leaving the current to flow through the switch contacts (which aren't greased).
    I wouldn't worry too much about the exact type of lubricant, as long as it is lubricating the threads, and is preventing the O rings from running dry.
    Clean the threads and O ring grooves once a month, more if you use in dusty/dirty/wet conditions, buy spare O rings, and use that light !
    Do something, or do nothing, but do it quickly, there's a line forming !!
    ______________________________________
    Nigel Whitaker - Performing random acts of aircraft engineering. My Photo Site
    G2z, 9P, 6P, L1, 8AX, 8NX, M3, M4, M6, Jil CR2 DD, C2 with SW02 Nice !..... ARC LSH-S, ARC AAA-P, THOR 10MCP, and Illuminated PC Keyboard. Z3_FOR_SALE
    Jan 2005
    San Francisco
    Thank you all for the suggestions! I'm still a little overwhelmed by all of these options- it looks like Nyogel 759G is preserves conductivity, but I'd prefer the thickness and aluminum-wear resistant properties of 779ZC... Ah well, thanks to 2dim, I decided to try out the Magnalube via yaesumofo's group buy- I figure if he's a flashaholic with over 1,062 posts and has used it on many lights with positive results, it's gotta work ok . The price was right to boot.
    Flashaholic* jar3ds's Avatar
    Sep 2005
    USA
    Default Local Sources for Good Silicon Grease?
    Is there any availible at wal-mart / radio-shack? etc? Thanks!
    Apr 2004
    BuckSnort
    Default Re: Local Sources for Good Silicon Grease?
    Quote Originally Posted by jar3ds
    Any 100% Silicon Grease should do for o-rings. Most autoparts stores sale a large tube for about $7, sometimes labeled dielectric grease. HomeDepot/Lowes also sales small 1oz tub's of it in the plumbing section. Just make sure its mark 100% Silicon Grease.
    Favortie Light: A2-BK-WH
    Sep 2005
    USA
    THANKS BUBA!
