Tri-lux heatsink for Maglite Rechargeable?
Erasmus
Belgium
Is there any tri-lux heatsink available for the Maglite Rechargeable? The Shoppe sells a tri-lux heatsink for Maglite D-cell flashlights, but I don't know whether they fit the Maglite Rechargeable (I asked them but they don't answer their e-mails).
Please help :)
Erasmus
Belgium
Specifications of the Maglite Rechargeable
Specifications of the Maglite D-cell
D-cell head diameter is 57mm, Rechargeable head diameter is 58,72mm.
The D-cell barrel diameter is equal to the barral diameter of the Rechargeable, it's 39.67mm.
Can someone check whether a D-cell head fits a Rechargeable? If a trilux heatsink isn't available for the Rechargeable, I can use a D-cell head to make the LED modification if the D-cell head fits the Rechargeable's barrel.
andrewwynn
Racine, WI USA
you can't interchange parts from the magcharger.. the head is not threaded on.. it uses a clever clip-in locking mechanism.. the frame around the reflector holds the head on the light.. the head does not move in/out when turning like the standard mags.. it just rotates in a continuous circle.
I will be designing a heatsink for the magcharger soon but 'soon' means in a month or two when i'm caught up on nanos and other things. I will be making a 'BAM' for magcharger.. it's a great host.
-awr
Timson
Leeds - England
I think the Magcharger is best kept as it is..... or upgraded with a WA1160.....
Seems like a waste of a pretty good stock system.
Don't get me wrong ...I'm a big Luxeon fan -
Just think you'd be best off buying a $20 2D Mag to mod with a tri-sink.
Just my 2 penneth.
Tim
andrewwynn
Racine, WI USA
'til the 4-lux bam mod for the mag charger is out.. comparable output to the 1160, no burning out.. and dimmable... much more usuable light for anything closer than 30-40 feet away.
However, the mag c is an awesome host and totall gimmie for the 1160.
-awr
