After months of torturous waiting, I finally received my Maxpedition Monsoon today. My initial impression is one of deep, heart-rending disappointment.
In fairness, the bag has a lot going for it. It's very nicely made and seems quite sturdy. In my eyes, it's the most stylish goodly-sized bag that Maxpedition makes. It has more compartments for organization than they tell you about, which is a nice surprise.
The bag is larger than I expected, but that's not necessarily a bad thing.
The bottom of the bag almost appears to be molded plastic in the pictures on the Maxpedition website. I was surprised to find that in fact it is some sort of textured, flexible plastic. Vinyl, I guess. It's also padded. That seems nice.
The triangular shape makes the internal space hard to optimize; at the moment, there is dead space near the top that I'm not really sure how to make use of. This is inherent to the style of the bag and I anticipated it. Possibly I'll work it out in the long run.
There are several detriments to the design, however, which I really wish I'd known about before I ordered it. Here's the most important:
If you just want to sling it over one shoulder, like you might a regular backpack, IT'S A LEFT-HANDED BAG.
Check out this image:
http://www.maxpedition.com/product/gearslinger/0410_monsoon/0410g_08.jpg
Looks like it's slung over the right shoulder, doesn't it? I now realize that guy is wearing the bag across his body, bandolier-style. The bit under his right arm - which I took to be the bottom connection point of the main strap - is where the integral belt connects. The main strap joins the bag body on the left side, and the ergonomic design ensures that you can only wear it over your left shoulder unless you opt for cross-body carry. On the left bottom side, where the strap connects, are several nice little pockets for storing stuff you want readily accessible. This is swell - if you're left-handed.
Other, more minor, detriments:
The main carry strap is long, much longer than I would have guessed, and cannot be adjusted to be shorter - only longer. If you were very tall, this would be comfy and reasonable. On me (and I'm only 5'6"), the bag seems to hang very low. I assume this is because I'm trying to sling the bag over one shoulder like a purse, while the bag seems to be optimized for cross-body wear.
The waist strap is described as "concealable" - in actuality there is a little elastic-snugged web pocket into which the belt mostly fits. This is neither concealed nor particularly secure. I'd be very surprised if the strap stayed in that little mesh bag during "hard use." Possibly this is unfair; we'll see.
The shoulder pad on the main strap seems outrageously wide to me.
There are a number of compression straps on the bag for adapting it to your particular load. They are, of course, adjustable, but they don't seem to stay where you put them. I tightened several of them up and they went right back to their factory positions as soon as I put the bag on.
The cinch cord on the water bottle carrier on my bag is assembled wrong. There is a little plastic compression thingy that's supposed to hold the cinch cord secure. The cinch cord goes through the wrong part of the compression thingy such that it doesn't work at all. I see no way to correct this without destroying the assembly.
Tonight I'll obsessively re-examine the bag and load my stuff in it as well as I can. I'm hoping that I can get used to the left-handedness of it and grow to like it. I'm going to experiment with cross-body carry and try to like it. For now, though, I'm feeling really let down.
