Warhoggie said:
Tapered reamer, is that the drill bit that have multiply steps in terms of hole size? Also you mentioned drilling from the inside. You mean to drill it from the non reflective side, the back of the reflector, right?
I didn't relize your reflector is aluminum. The tapered reamers I have in mind are hand tools, not stepped, with a t handle built in for turning. They may also be made for drill motors.
I drilled my plastic reflectors from the inside because drilling from the other (non reflective) side caused an off-center hole.
If you put too much pressure on the aluminum, like placing it in a vise, you will likely distort your very pretty and expensive reflector. Not good!
Try this: Weatherstripping double sided, foam backed tape, placed on a piece of wood, which will keep you from drilling into the wife's table, countertop, or other priceless heirloom. Build up an area as large as you like by placing the strips side by side.Take the backing off, and press the reflector firmly onto the stickum, steady it with one hand, and drill with the other one. It should hold securely, and clean off easily.
No doubt, someone else will have a better solution, because on occassion, I have been accused of making stuff harder than it needs to be. (Totally without justification, I might add.)
Again: slow and easy!
