Hey,
I got around to installing some of the boards in some DD mods I have done...really nice!!!
First one, 3d m@g, I cutout the two LDO's and stuck them underside of the o-sink...
I have yet to test what voltage it starts to drop out at...(3d)
second, 3d m@g, board intact, fitted under the o-sink
also you could do a 1C (2/cr123) m@g trilux or quad using 1w lux (with 1 1/2-2) boards worth of LDO's & still be under the 1400ma max drain...a bit of a waste of power running @, 6v but it would be a cheap pocket rocket...
the strengths of this board is for extending the runtime for DD mods, ie 3 nimh/alk cell DD mods...
I tried 3C & 3AA into the LDO, but did not get full output from the driver...
I will try to get some of the SOT252's...
But due to the 70degC on the SOT89 I am running them with NO led installed, in a remote local...
Hey CY how did you go with your trilux???
ktronik
just checked with AW, both packages go upto 120degC, I read the data sheet wrong...
sorry to all...
