Quote:
Originally Posted by BatteryCharger
And the question is, how much of that 60 watts is turned into heat, how much is turned into light, and how much is turned into other, in different types of lighting?
Of course it varies greatly even for a given type of light but here are some ballpark figures in rough order of efficiency:
4 watt night light bulb: 2.5% light, 97.5% heat
100 watt incandescent: 9% light, 91% heat
1 watt Luxeon (45 lumens): 12% light, 88% heat
500 watt projector incandescent: 18% light, 82% heat
40 watt T-12 fluorescent (excluding ballast losses): 20% light, 80% heat
32 watt T-8 fluorescent (excluding ballast losses): 27% light, 73% heat
400 watt HID: 30% light, 70% heat
250 watt low-pressure sodium: 40% light, 60% heat
Cree XT-27 blue LED die: 42% light, 58% heat
Note that conversion efficiency figures cannot necessarily be correlated with lumens per watt due to the differing efficacies of the emitted spectrums. For example, if we could produce an incandescent light specturm with 100% efficiency we would only be at 200 lm/W but a white LED type spectrum might give us 300 to 400 lm/W. Also note that low-pressure sodium lamps emit entirely at one wavelength with a luminous efficacy of over 500 lm/W. I also didn't include "other" because as far as I know whatever isn't emitted as light is emitted as heat although small amounts of UV may escape the tubes of some discharge lamps.
