Hi Folks,
I've got 2 shop lights over my workbench that came with the house and have never put out much light. They are dim and flickery and I suspect that the ballasts in both of them are toast because new bulbs dont fix the problem.
I wanted to get a decent electronic ballast for them, but HD here doesn't carry an electronic ballast for anything but T8 bulbs, and these are the older fixtures for T12 bulbs.
Folks around here love T8 bulbs, more efficient brighter and such. But as I've looked at the specs, it doesn't actually show this. The lumen output on the T8 bulbs is less than the T12 bulbs on the package anyway.
Is this true? If I was going to buy a new ballast, should I get a T8 ballast and put t* bulbs in? or not worry about it.
The other problem I have is the sockets, would a T8 bulb go into a socket for a T12 bulb? just eyeballing it at the hardware store the pins look to be the same separation. They sell separate tube sockets, but they aren't labeled for T8 or T12, just "medium" or something equally as helpful.
I suppose i could just replace the whole fixture if I was going to replace the ballast and the sockets, whats left but some sheet metal
But that is more expensive then as I'd want to get really bright 4 tube models or something.
So help me figure out if I can retrofit these for T8 bulbs and if I'd want to anyway?
Thanks!
