CandlePowerForums
CPF Only
User Name
Password
Register
HDS Systems
Reply
Thread Tools Display Modes
  #1
Old 01-26-2006, 09:05 AM
tech tech is offline
Question Replacing a Dodge map LED????
I'm not which forum to put this in, so I'll start with this one:
I have a 2002 Dodge Grand Caravan.
On the inside roof, between the trip computer and sunglasses holder, there is a green LED that is always on when the ignition is on.
It is green, and I want to replace it with a red LED.
I'm waiting for a call back from the Dodge dealer, but was hoping that someone on this board might have ideas on how to replace it, and what to replace it with.
Anyone?
T.
  #2
Old 01-26-2006, 09:39 AM
Changchung's Avatar
Changchung Changchung is offline
Default Re: Replacing a Dodge map LED????
Hi my friend, that is not a problem, i have a lot of experience doing mods in cars, replacement bulbs for Leds, you have to take out that bulb and make some mod and put a Led there, if is a 5mm Led connect with a resistor, 560 Ohm 1/4 watts, is not a big problem... if you put a bigger Led like a Luxeon Led maybe you need some extra thinks... if you need any help let me know...
Check This Out...
http://www.taskled.com/history.html
http://www.taskled.com/install.html
__________________
Inova X1 T1 T2 T4 Ultrafire Element Dorcy Mag Nuwai Mod Quad K2 & many many more Camera Pentax M10
  #3
Old 01-26-2006, 05:50 PM
Ken_McE's Avatar
Ken_McE Ken_McE is offline
Are you able to open up the housing to the point where you have a clear view of the LED? The simplest thing to try would be to find a red LED the same size as the green one and see if it will run in that spot. Are you able to tell what current/voltage is going to it?
  #4
Old 01-27-2006, 01:16 PM
I am going to try to get into the housing where the LED is and see what is going on.
One concern is that I don't want to make a mess, the wife would just love that!
The other concern is that this turns on when the headlights are on.
When the headlights are turned on, it turns on, and the trip computer dims...so I don't know if this led is somehow connected to the trip computer.
I'm going to see what I can figure out...
Changchung, if I just replace the green led with a red led, would I need to add a resistor, or just use what is already there?
Any other helpful suggestions, please let me know!
T.
  #5
Old 01-30-2006, 11:15 PM
scott.cr scott.cr is offline
Ooooh, I know this LED you speak of, it is probably surface mount. You'll need a real steady hand to replace it. Or a can of red spray dye. ;-)
  #6
Old 02-11-2006, 01:20 PM
rudbwoy69camaro's Avatar
rudbwoy69camaro rudbwoy69camaro is offline
Help Re: Replacing a Dodge map LED????
I have a GMT-800, a 2002 Tahoe to be specific. I was thinking about Lux I's for the DaytimeRunningLights. The questions I have are: Will it be too bright for oncoming traffic? I noticed that dirt and a bit of moisture gets in the lense where the bulb is housed(bulb type is 4157). Driver board-how to waterproof? Sorry, I am still a FNG on here and learning...
Quote:
Check This Out...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
