CandlePowerForums
CPF Only
User Name
Password
Register
OLight at Battery Junction
Reply
Thread Tools Display Modes
  #1
Old 02-16-2006, 02:26 AM
Handlobraesing Handlobraesing is offline
Banned
Default Check out this HUGE metal halide bulb I bought
Not that I have a use for it, but I picked one up from my school's Surplus Property department for $3, just so I can use it as a piece of decora.
1,500W sports lighting lamp.
  #2
Old 02-16-2006, 10:26 AM
greenlight's Avatar
greenlight greenlight is offline
Default Re: Check out this HUGE metal halide bulb I bought
Or something else...
  #3
Old 02-16-2006, 01:13 PM
James S's Avatar
James S James S is offline
*Flashaholic*
Might want to build a better stand for that, arne't those under some amount of pressure inside? If that fell off you'd be picking quarts and glass and bits of wire out of your face/eyes/backside etc for quite a while...
__________________
-James
E=sqrt((mc^2)^2+(pc)^2)
  #4
Old 02-16-2006, 05:46 PM
BatteryCharger's Avatar
BatteryCharger BatteryCharger is offline
Quote:
I think they're actually under a vacuum, so it should just implode. Maybe the little "thing" in the center is under pressure, I don't really know...
__________________
I got a fever and the only prescription is more cowbell.
  #5
Old 02-16-2006, 05:55 PM
hector hector is offline
TVs are under a vacuum, and if one explodes, you will never get all the glass out of your body. That light is a bomb.
  #6
PhotonWrangler's Avatar
PhotonWrangler PhotonWrangler is offline
*Flashaholic*
That's a pretty impressive lamp. I wonder if the arc capsule is tilted for a particular beam pattern, or if it's made that way to reduce the overall height of the envelope.
__________________
The future ain't what it used to be.
  #7
Old 02-16-2006, 07:22 PM
Quote:
I've seen a TV smash into concrete very near me, it imploded rather harmlessly. It is not possible for something under vacuum to explode unless you add explosives.
__________________
  #8
Old 02-16-2006, 10:27 PM
MXDan MXDan is offline
Regardless, I think it's pretty cool!
__________________
Religion is the opium of the people.
-K. Marx
  #9
Old 02-16-2006, 11:19 PM
yuandrew's Avatar
yuandrew yuandrew is offline
Stadium Flood light
I think the reason the arc tube is slanted like that is so that when installed in an angled socket/reflector, it would burn in the horizontal position. It probably also has something to do with the beam pattern. A lot of stadium flood lights I've seen use lamps with arc tubes tilted like that
http://www.bulbs.com/products/produc...nventory=12516
Find yourself a 20 amp 120volt (240 or 277 will also work; its a multitap ballast anyway) and get a pair of sunglasses.
Normal application
www.musco.com
And yes, that arc tube is probably around 2 atmospheres pressure when cold. Don't let it fall. Even if the HID explosion dosen't kill anyone, it will be quite a mess to clean up. Not to mention that those lamps do contain mercury.
  #10
Old 02-16-2006, 11:43 PM
scott.cr scott.cr is offline
That'd make a great 5-gallon jerrycan for your spare gasoline. ;-)
  #11
Old 02-17-2006, 03:49 AM
Banned
Quote:
Originally Posted by yuandrew
Stadium Flood light
Normal application
www.musco.com
That design is patented by Musco.
This is the reason:
  #12
Old 02-18-2006, 07:52 PM
perfectname perfectname is offline
deleted
  #13
Old 02-18-2006, 08:27 PM
*Flashaholic*
Quote:
This is the reason:
Thanks Yuandrew for the explanation and the great drawing, Handlobraesing!
__________________
  #14
Old 02-18-2006, 08:34 PM
Quote:
I Googled this, (yes, very scientific research), but I guess TVs have a layer of tough protective polymer sandwiched in which prevents the glass from shattering all over. Thus, my mom lied to me when she told me the TV would explode if I threw stuff at it.
www.zyra.org.uk/tvtube2.htm[/url] describes the glass imploding then flying outward.
www.kronjaeger.com/hv/hv/exp/pump/[/url] also cautions against it.
  #15
Old 02-21-2006, 03:21 AM
OddBall OddBall is offline
Anyway, it looks cool - maybe just make a cool holder/stand for it? Glow in the dark holder would make for a snazzy backlight...
__________________
GLOW ME TOO WHILE YOU'RE AT IT!!
  #16
Old 02-21-2006, 06:42 AM
bfg9000's Avatar
bfg9000 bfg9000 is offline
I'd try to get the ballast for it. Would make a fine nightlight for the true flashaholic.
  #17
Old 02-25-2006, 03:57 PM
scaredofthedark scaredofthedark is offline
Quote:
nightlight??
i dunno how you can sleep with a miniture star in your bedroom hahaha
  #18
Old 03-11-2006, 05:52 AM
Banned
hmm rated at some 160,000 lumens.
  #19
Old 03-12-2006, 09:11 AM
snakebite's Avatar
snakebite snakebite is offline
dont operate it outside a proper enclosure designed to contain an explosion.
it may make a good bang cold but the pressure is about 20 atmospheres hot.and a common failure mode is arc tube rupture while operating.and if the explosion is not bad enough you have nearly white hot quartz shrapnel to deal with too.
__________________
i am always looking for old radios and tv sets.tube stuff.ham gear.i repair all the above.
email me for more info. SPAMMERS WILL BE PUNISHED!
  #20
Old 03-12-2006, 09:31 AM
watt4's Avatar
watt4 watt4 is offline
very cool. makes me think of flashaholic decoration themes.
need to make a proper flashlight body to hold it. five gallon bucket might work.
then send pics of the super flashlight around the net for comments
btw, that thing will fall over if left like that. only a matter of time.
  #21
Old 03-12-2006, 09:43 AM
nakahoshi's Avatar
nakahoshi nakahoshi is offline
I have to change those bulbs all the time, so i dont share the same enjoyment as you do. more of a pain, trying to get into the fixture if there is a lense, ect. There pretty awesome though, when they first get power the inner tube glows blue and pulsates for a little bit. You cant watch them too much though, Unless your blind to begin with.
-bobby
__________________
MLR<3
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
