CandlePowerForums
CPF Only
User Name
Password
Register
Advertising on CPF!
Reply
Thread Tools Display Modes
  #1
Old 03-13-2006, 04:26 PM
MacGyver MacGyver is offline
Default 25W 'Shoplight' Tubes?
I found some of these recently, F48/25W/UTSL.
What is the advantage over something more mainstream, like 'regular' cool white F34CW/RS/WM tubes?
The 25W ones are same life, same CRI, lower lumens output according to the GE fluorescent PDF I have.
Is that it, just for any application where you may not want as much light as possible?
Seems I always want more so I'm curious
Thanks
  #2
Old 03-13-2006, 04:43 PM
winny winny is offline
Default Re: 25W 'Shoplight' Tubes?
I'm not sure what florescent tubes you are talking about, but in general, you sometimes want to over-render red (compared to standard florescent tubes or sometimes even compared to incans, especially when it comes to bread and flowers). The CRI-value won't tell if you over-render a certain color, you would need to look at the color vector diagram for that.
That could be a reason why it isn't as efficient as regular tubes.
Other explanations are what shorter tubes (less powerful) aren't as efficient or that your model just isn't a very efficient tube.
I hope that might have straighten out at least something for you.
__________________
Still no response to that PM or e-mail you sent me two months ago? Try sending it again. I'm terrible at keeping track of messages.
  #3
Old 03-14-2006, 12:42 AM
jtr1962 jtr1962 is offline
There is no advantage to them. All 25 watt shoplight tubes are is an "energy saving" version of standard 40 watt tubes with proportionally less output. I looked at the specs for these and they had 1860 initial lumens (74.4 lm/W) and a CRI of only 60. In short, they had no efficiency advantage over better tubes and the color rendering is absolutely horrible. Honestly, given how cheap tri-phosphor tubes with decent color rendering and better efficiency are these days, I really don't know why tubes like this are even made any more. When running on a magnetic ballast between the flicker and poor color they're a perfect recipe for migraines, and one of the reasons people say they hate fluorescent lighting.
My advice-stay away from them. They won't work in most standard 4-foot tube fixtures anyway. Get a decent T8 electronically ballasted fixture and a set of decent tubes. SPX phosphor tubes have a CRI of 86 and are fairly cheap, plus available in all the common color temperatures (3000K, 3500K, 4100K, 5000K, 6500K). If you want to spend somewhat more, you can get full-spectrum 5000K tubes with a CRI of 91 to 93.
  #4
Old 03-14-2006, 10:08 AM
jtr1962, I was thinking along those lines, thank you for confirming my suspicions, and the detailed explanation
winny, you probably don't have the exact same tubes available in Europe then, my numbers above are for standard 48" GE ones here.
Of course, as jtr1962's pointed out, you're not missing anything
Well, as indifferent as I've been to electronic ballasted linear T8 tubes...mebbe it's time to join this century & try some out...
  #5
Old 03-23-2006, 12:55 PM
Handlobraesing Handlobraesing is offline
Banned
The 25W 48" lamp is the same as a regular 40 watt. They market it as 25W for residential use with low-output shop light ballast, as to make it legal.
The F40T12 Cool White 40W type lamp intended for use on full output, commercial rated, 40W ballast is outlawed under EPACT.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
