CandlePowerForums
CPF Only
User Name
Password
Register
Peak LES
Reply
Thread Tools Display Modes
  #1
Old 03-24-2006, 07:39 PM
yuandrew's Avatar
yuandrew yuandrew is offline
Default Automotive HID for home lighting
Call me crazy but that's what I'm using for my room right now. I recently bought an HID ballast (Denso/Toyota) and D2R lamp off Ebay for the purpose of building something portable but I ended up putting the ballast on top of my bookshelf with the bare bulb hanging off the side.
For 35 watts (excluding ballast and power supply losses) I get a lot of light; it blinds you if you look at the bare lamp. I find automotive lamps ok for my use; mainly because of the quick warmup time and instant re-strike capability. The only disadvantage I have is the 12 volt ballast; I'm using a old computer power supply to get the 12 volts.
Any comments or concerns?
  #2
Old 03-24-2006, 07:57 PM
igabo's Avatar
igabo igabo is offline
Default Re: Automotive HID for home lighting
Could you get a "beamshot" of the entire room? I'd like to see.
__________________
Poor student with habit detrimental to wallet.
All donations appreciated.
  #3
Old 03-24-2006, 09:08 PM
yuandrew's Avatar
Here's the ballast
  #4
Old 03-25-2006, 06:40 AM
snakebite's Avatar
snakebite snakebite is offline
i built an outdoor light for my 12v system here from a ballast/lamp from a wrecked lexus.
it works very well.
you need to enclose the bulb in case of "non passive end of life "(explosion of the arc tube)
which may throw white hot debris causing injury or fire.
__________________
i am always looking for old radios and tv sets.tube stuff.ham gear.i repair all the above.
email me for more info. SPAMMERS WILL BE PUNISHED!
  #5
Old 03-25-2006, 07:55 AM
Handlobraesing Handlobraesing is offline
Banned
Not a good idea. Automotive HIDs are only rated for 2,000 hours of life and they cost a bunch, which should be more or less the lifetime of the car, notwithstanding collision damage.
If you use it as a room lighting, which gets left on for hours at a time on regular basis, 2,000 hours is only twice the life of an ordinary 60 watt light bulb. The lamp cost so much that the cost of operation far exceeds that of a 150 watt halogen lamp. You'll get a better efficiency and equal usability out of a large CFL (30-40watt) which are readily availalbe these days.
  #6
Old 03-26-2006, 07:45 AM
bfg9000's Avatar
bfg9000 bfg9000 is offline
Is the outer envelope on those bare HID bulbs quartz or soda glass? The reason I ask is quartz doesn't filter UV so you may be getting a tan...
  #7
Old 03-31-2006, 07:26 PM
yuandrew's Avatar
They are made from quartz but the quartz I heard is treated with cerium to block the UV light. Otherwise, the UV from it will degrade the plastic headlight lenses.
I don't use it too often but it actually came in handy last night. The power went out early this morning and I just happened to have a cordless drill. I connected the battery and left it there for some emergency lighting. I only used it for a few mins though, the drill battery dosen't last long but I went back to sleep anyway.
I did have a little trouble with my DSL modem after the power came back on this morning. Took me all day to reconfigure it to work with my router.
  #8
Old 04-02-2006, 01:25 PM
reefphilic's Avatar
reefphilic reefphilic is offline
I have HID lights for my fish tank. Used it once to light up the living room. It was fantastic, the whole room lit up like it was daytime! Hate those dim, yellowish power compact.
Thought of using HID for my living room but couldn't find any suitable light fixture for it.
  #9
Old 04-02-2006, 01:28 PM
Banned
Unless your house has a Wal-Mart high ceiling, why not use fluorescent?
  #10
Old 04-04-2006, 11:52 AM
reefphilic's Avatar
Quote:
HID has a higher efficiency than fluorescent tube so it will take rows of flourescent to have equivalent output of a single 150W metal halide bulb. I don't want my living room's ceiling to look like an office's.
  #11
Old 04-07-2006, 04:35 PM
HEY HEY ITS HENDO's Avatar
HEY HEY ITS HENDO HEY HEY ITS HENDO is offline
Quote:
Originally Posted by yuandrew
Call me crazy
..... crazy? just like the rest of us !! (Nice pics BTW)
i had a similar set up it, was controlled by a timer and would come on 10 minutes before my morning wake up alarm, i found that on dark winter mornings it really did help me to wake up .....
i really did like it at first, but the light colour is very bright white and seems `cold` looking, now i just use a compact fluorescent
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
