Nite Glow rings
I recently bought 3 of the latest Mk 111 Nite Glow rings and one of the older X2's. At purchase all of the rings were new and all in first class condition. After only a few weeks of gentle use on the end of a couple of key rings, two of the rings have noticeable cracking around the ends where the stopper is located. Although none have failed I was so concerned about them failing and loosing the tritium vials that I made a couple of end pieces for them and glued them on.
I have today emailed Nite about this as the Glow rings were obtained from seperate UK buyers and I think it very unlikely that I could have been unlucky enough to have bought two faulty rings from two seperate sources?
The purpose of this post is to ask you guys to check your glo rings to see if you are having the same problem or is it just my bad luck?
Doug
__________________
SFG2's x 2 SFG2z x1, E2e+KL1,E2e,Maglites: 1x2D with 1x3D original,1x2C,1x3C,3xAA's 2 with Opalec Newbeams, 1 with a Terrlux,1xAAA with MJLED ,Ix3C Propolymer SL,1x SL Stinger ,CMG Infinity (blue LED), CMG Ultra, 1x Black, Night Ops Gladius
