CandlePowerForums
CPF Only
User Name
Password
Register
Fenixgear
Reply
Thread Tools Display Modes
  #1
Old 04-09-2006, 11:26 PM
GotCoffee GotCoffee is offline
Question Solar charged SLA, LED lights
I'm trying to build a solar charger for a 12V 7Ah SLA battery that will power 12 white LEDs (3.5V @ 20 mA) 24-7. The LEDs are set up in three groups, 3 LEDs in two different bathrooms and 6 in the hallway.
I was thinking of series 3 LEDs with a 75 ohm resister. The max I for these LEDs are 30mA.
Does anyone know where I get a charger for the SLA of a schematic on how to build one. I'm pretty good with a soldering iron. I have been searching mouser.com for an IC that would charge an SLA and then float charge to no avail. The charger or circuit will be powered from 12V similar to http://www.siliconsolar.com/shop/cat...ger-p-133.html
Thanks,
Ray
  #2
Old 04-10-2006, 02:07 AM
bfg9000's Avatar
bfg9000 bfg9000 is offline
Default Re: Solar charged SLA, LED lights
The $10 price of a pre-built: http://www.harborfreight.com/cpi/cta...emnumber=44768 makes it kind of difficult to consider building one. SLA will absorb the slight overcharge from such low currents without issue so this is already as low as float chargers go in UPSes, emergency lights and other applications those SLA are commonly used in.
  #3
Old 04-10-2006, 03:32 AM
bfg9000's Avatar
Of course if you insist on fast charge + float:
http://www.arsqrp.com/ars/pages/back...ext/N7CEE.html
http://users.picbasic.org/projects/S...controller.htm
http://www.uoguelph.ca/~antoon/gadgets/labc2.htm
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
