04-12-2006, 04:55 PM
LED low-beam headlights have arrived.
and you can find them on the newest uber-Lexus.
three on each side, with projector lenses.
hawt.
http://www.autoblog.com/2006/04/12/n...xus-ls-600h-l/
04-12-2006, 06:41 PM
Re: LED low-beam headlights have arrived.
Not bad, not bad...now somebody just make a good replacement for the bulbs we all have and we're set!!
AC "My taillights and CHMSL are LED-ified" Marina
__________________
I love my Al-PD
04-13-2006, 06:38 AM
meh....3 only... i rather wait for elektrolumen to create a k2 stunner of cars as headlamps :P
__________________
if killing was legal, i would have killed countless number of people...
04-14-2006, 12:09 PM
Not possible, I'm afraid.
Current headlamp reflectors are designed for a filament that is visible from more angles than a heatsinked LED can be.
Drop-in LED replacement headlamp bulbs are, I think, not going to happen.
04-16-2006, 04:25 AM
Looking closely at the pictures, It looks like the Lexus LED headlamps are using small projector housings to focus their beams. Like current HID headlights that use projector lenses, I'm sure they've got cut-off patterns built in them too.
I've been trying to search more info on these LEDs but can't seem to find anything about them. As secretive as these LED manufacturers are...I doubt I'll be able to find much of anything.
Just some thoughts about there efficiency...
Probably, for an DOT approved headlight to be affective, they've got to be at least as bright as halogen headlights. One halogen 55W bulb produces around 1400 lumens (Taking a guess using my Thor as a benchmark). One HID 35W bulb does around 3200 lumens....
If the new LED headlights on the Lexus uses only 3 LEDs per headlight then we could figure how much light each LED produces, assuming they must compete with older lighting technology at 1400-3200 lumens.
1400-3200 lumens / 3 LEDs = 467-1067 lumens PER LED.
Have LEDs reached the 500 lumen mark at least? Can you imagine what kind of heatsinking is required per headlight?
__________________
-Laurence
04-16-2006, 07:51 AM
*Flashaholic*
I like the LED headlights, but all the rest of that stuff in that car is creepy. It watches the road with 2 cameras and it watches you with another while you're driving and if you're not looking in the direction where it thinks there is a problem it sounds an alarm and can apply your brakes for you! And finally it adjusts the stearing ratio so that you turn faster to avoid the problem! That last one is scary, if I'm swerving to avoid something and the wheels turn harder than I wanted them to I think it's much more likely you'll roll the car or end up in the ditch. But I suppose they have thought of all that...
Makes this article sound all the more closer to the truth
Motorist trapped in traffic circle for 14 hours
NOTE: before reacting too strongly to the linked article, be sure to verify the date and understand the american cultural significance of said date. If you dont understand, then I'm sure someone can explain it to you before you say anything too foolish
__________________
-James
E=sqrt((mc^2)^2+(pc)^2)
04-19-2006, 12:36 AM
Quote:
1400/60 lumens = 23 Luxeon IIIs to replace one conventional bulb. Seems to me that you could put the lot of them into a single assembly, a stripe along the top of the bumper / bottom of the hood. A narrow beam from each LED would be OK as they could all be aimed (by molding the reflectors in the assembly) to have whatever beam pattern the designer wants.
Seems to me that it's do-able now with current LEDs, and will only get easier as LED techology improves. I don't think it's that far off.
04-19-2006, 12:32 PM
Let's round up to 25 Lux3's.
Okay.... So you'd need a 2" high by 1' long strip for each side for the low beams. That's not even counting optics.
Also, do you think that an array of 25 luxeons with 1 cubic inch optics will be able to throw as far as the standard ~8" wide parabolic reflectors and their 55w halogen bulbs?
I figure that a more even pattern of light can be acheived with 25 elements, but i'm not sure if it can cover the road as far as standard DOT lamps.
04-20-2006, 02:25 AM
I really don't think this headlight system is using THAT many LEDs in the assembly. The picture shown above is from the protoype Lexus being disussed.
It looks like there is only one LED per optic. From what I understand about optics, i don't think it is possible to have multiple light sources in one optic.
Surefire is already experimenting with 10W and 100W LEDs. Posts from CPF member: Newbie, have revealed other manufacturers achiving up to 7000 lumens per LED....70lm/watt.
Can you imagine how bright 3 LEDs would be if they could output at least 5000 lumens? I think we'll start driving at night with the power of airplane landing lights. NICE!
__________________
-Laurence
04-20-2006, 11:50 AM
Of course it's possible to have more than one light source per optic. You just have to plot out where the light is going to go beforehand.
IE: two elements : and one lens () with two projections <
you could easily have two or three (or more) LED's per optic, depending on the shape of the lens.
04-20-2006, 11:30 PM
I'm not saying this would be a drop-in replacement.  But I could see front ends designed around something like this, especially sports cars where the nose tends to be not much taller than the bumper necessitates.
And yes I do think they would have throw comparable to conventional headlights. (It not, use twice as many and make the strip 2" tall instead.)
LEDAgent: yeah, looks like three to me too. But my point was just that LED low-beams don't require big technological advances. They are possible with today's technology - and flashlight technology, at that - so I would not be at all surprised to see them in production in a couple years.
04-23-2006, 12:11 PM
I've seen a number of car manufacturers showcasing prototype LED headlights, including Audi, Land Rover, Lexus...Off the top of my head
All had multiple emitters.
With that 3 lamp Lexus set-up...Who knows how many emitters are behind each projector lense.
Have a look at this shot of the Audi Nuvolari.
I see 18 emitters on each side for the dipped beam. At 3 W per emitter that would equate to standard front headlight wattage (Around 55W)
Tim.
__________________
M3-CB, C3-HAIII, A2-RD, Fenix L1P, Fenix P1D-CE, Tri-Star Phaser, Inova T3, Mag85, SNII Clone, DD LuxIII Mag,
Trilobike , Hot-Diver
04-24-2006, 07:14 AM
I'll have to dig this one up- in one of my car magazines/catalogs (I think it was a German parts catalog) there was a mini-feature on the latest Audi DTM racer. It utilizes LED headlights that were being used as a prototype for production.
__________________
A few favorite lights from: McGizmo, Data, milkyspit, HDS, and Surefire
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
