CandlePowerForums
CPF Only
User Name
Password
Register
OLight at Battery Junction
Reply
Thread Tools Display Modes
  #1
Old 04-23-2006, 11:29 AM
sphynx_000 sphynx_000 is offline
Default driving at halogen bulb at a higher voltage?
I was looking at this,http://www.instructables.com/ex/i/91...E506/?ALLSTEPS
Is there any way I could run 2x 7.2 volt battery packs to a 12 volt halogen light?
  #2
Old 04-23-2006, 11:36 AM
FirstDsent's Avatar
FirstDsent FirstDsent is offline
Default Re: driving at halogen bulb at a higher voltage?
You have posted an incandescent thread to the LED forum. You will find the folks on the incandescent forum better informed on matters such as this.
IMO, that's a lot of overdrive. 17% overdrive to be exact. May make a flashcube instead. It may be possible if you use a resistor to drop the voltage. If you just want to use that power pack, that may be your solution.
Bernie
__________________
If it's worth driving, it's worth overdriving!
  #3
Old 04-23-2006, 11:38 AM
sorry,
I forgot I was still in the LED section.
  #4
Old 04-23-2006, 11:45 AM
Bernie
what is a flashcube?
  #5
Old 04-23-2006, 11:55 AM
legtu's Avatar
legtu legtu is offline
Hmmm... I think it'll run just fine. MR-16's are usually underdriven at 12v and depending on current draw, there's also voltage sag.
__________________
  #6
Old 04-23-2006, 12:01 PM
I think ill have to try that, being it will cost me almost nothing.
Anyways, how do i calculate the resister value to drop voltage?
EDIT: People on that link talk about using 14.4 volt battery packs with the light. Sounds like it works fine, and if not, no big loss burning up a 4 dollar bulb.
  #7
Old 04-23-2006, 12:47 PM
FirstDsent's Avatar
Quote:
Well, you young whippersnappers wouldn't know I guess. Waaaay back in the 1970s, "110" cameras used a disposable flash cube because the compact strobe wasn't available in small/cheap cameras. They used a mechanical striker that ignited the flash. Eeach cube had four flashes, and rotated automatically when you cocked the camrea. I have to laugh every time I think about it. That wasn't that long ago!
Showing my age,
Bernie
__________________
  #8
Old 04-23-2006, 01:18 PM
Brighteyez Brighteyez is offline
That was my first thought when I saw your first post. How many people actually remember what a flashcube or flashbulb was?
As age can contribute to premature dementia (!), I seem to remember that the flashcubes were well in use by the mid-late 60's as a replacement to the AG-1 flashbulbs. And I think they were more commonly used in 126 (square 35mm format) cameras well before the 110 cameras appeared on the scene. But I'm not so sure that my memory is all that good either On the other hand, you know what they say about the 60's, "If you remember the 60's, you weren't there"
Showing my age,
Bernie
  #9
Old 04-23-2006, 01:22 PM
Before you start, you may want to also take into consideration that many incandecent bulbs are already being overdriven in their 'recommended' voltage usage. e.g. a bulb being used in a 3 cell light (4.5 nominal voltage) may actually be rated for something in the 3.5-3.7 range, and many of the bulbs being used in the 2 cell CR123 incandescent lights are actually rated for less than 5V.
  #10
Old 04-24-2006, 10:18 AM
RoyJ RoyJ is offline
Remember, 12V automotive bulbs are operating at around 14.4V when the alternator is running. Should be fine.
  #11
Old 04-24-2006, 05:39 PM
winny winny is offline
Overdriving a 12 V bulb to 14.4 would cause its lifetime to drop down to 0.0957 of its rated life. Unless it has got really short life at 12 V you should be fine.
__________________
Still no response to that PM or e-mail you sent me two months ago? Try sending it again. I'm terrible at keeping track of messages.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
