CandlePowerForums
CPF Only
User Name
Password
Register
Surefire at Battery Junction
Reply
Thread Tools Display Modes
  #1
Old 06-07-2006, 05:50 PM
EOppie EOppie is offline
Help LED Conversion in Tail Light,Problems 7-6-06
Hey guys, I admit, I'm a newbie here to the LED world...however I am starting a project that I need a bit of help on.
I am in the process of converting my tail lights on my 06 Ford Escape Hybrid to LED. I Also plan on using multiple colors in the reverse light housing to replace hideaway strobes I currently use as an EMT/Fire Fighter.
My first question I am running into is how to drive the LED. I am looking at using 4 Luxeon LXHL-LH3C Red-Orange Luxeon® III Star's in a square pattern for the tail lamp, then add another 5 that would illuminate for the stop lamp. (is this overkill?) I believe I need to use a driver to power the lamps, such as the CC5W from taskled.com to power the lamps.
I would also use Luxeons for the turn signals (Amber) and then others for the emergency lighting.
I would love any reccomendations or Advice people have!!
-Oppie
  #2
Old 06-08-2006, 03:01 AM
chesterqw's Avatar
chesterqw chesterqw is offline
Default Re: LED Conversion in Tail Light, Questions
i think warren has some tail light replacement luxeon lamp.
not sure if they fit but... www.litemania.com
you don't need to know korean to view the stuff there.
__________________
if killing was legal, i would have killed countless number of people...
  #3
Old 06-08-2006, 06:00 AM
I am trying to steer clear of the screw in type replacements. I think that only 1 Luxeon Star is not enough to meet the DOT requirements for minimum light output. Now I realize that even if I do meet the DOT requirements by using multiple LED's, it still will not be DOT approved without submitting it for approval.
With help from George over at taskled.com I think I may reduce the number of LED's required for the job. How many Luxeon Stars in red-orange do people reccomend?
  #4
Old 06-08-2006, 06:58 PM
Default Re: LED Conversion in Tail Light, Updated ?'s
My current plan is to use a total of 6 Luxeon III Red-Orange LED's total per tail/stop lamp. I would use 2 seperate drivers, with 3 wired to one for tail, and the other 3 wired to the other for stop. Obviously the tail's would stay on when the brake was depressed, thus having a total of 6 in one lamp housing.
Do people think this is overkill? I have not worked with them yet, and really don't know what to expect with brightness, especially through the rear lens.
  #5
Old 06-08-2006, 07:25 PM
Default Re: LED Conversion in Tail Light, Updated ?'s SuperFlux?
Another idea I am toying around with is the use of SuperFlux LED's...however can't find much application info on them. I realize that I would need many more of them...however at $0.39 a piece, the price is definitely right! I calculate...which is probably wrong... that in order to equal all of the 6 Stars in the above setup, I would need around 95 of these pieces...
What do people think?
  #6
Old 06-08-2006, 08:30 PM
pec50 pec50 is offline
You might find a conversion of some of the truckers' replacement leds as potentially less expensive while still meeting DOT requirements. You will also probably need to replace the flasher unit with a variable load unit to compensate for the lighter resistance load.
  #7
Old 06-09-2006, 05:05 PM
s0crates82 s0crates82 is offline
I think 6 Lux III red-orange's would be blinding and irresponsible. I'm not trying to be mean or insulting, I'm just concerned for those that share the road with you.
Consider using a total of 4. Even four will be significantly brighter than the stock lamps.
  #8
Old 06-09-2006, 10:27 PM
Thanks for the reccomendation...I really was looking for this exact kind of guidance!
I imagine I could also use 1W Lux's instead, or 2 III's for the Brake, and only 1 for the tail...what do people think?
  #9
Old 06-09-2006, 11:11 PM
Changchung's Avatar
Changchung Changchung is offline
You can used this option, easy, cheap and great results, simple, 5mm Leds... Any question, let me know...
__________________
Inova X1 T1 T2 T4 Ultrafire Element Dorcy Mag Nuwai Mod Quad K2 & many many more Camera Pentax M10
  #10
Old 06-09-2006, 11:35 PM
Nice look! Is this only for Tail, and then the brake light is still the standard filament? I bit the bullet and bought some Lux's already, few 1W and a few III's will be driving them with the drivers form taskled.com thanks to so much help from George...I will let you know of the results, and pics!
  #11
Old 06-10-2006, 08:19 AM
wasBlinded wasBlinded is offline
Be sure to come up with a decent heat-sink and a way to flow some air past it, or all those Luxeons will get very hot - and perhaps fail.
  #12
Old 06-10-2006, 10:00 PM
Right now the plan is to use 2 1W lux's for the tail lights, and 2 III's for the brake lamp. I realize I may have to underdrive the tail lights if they are too bright. I also plan on connecting them to a heat sink that would be connected outside the lamp area where there would be air moving around it.
  #13
Old 06-12-2006, 08:45 PM
Changchung's Avatar
I am using the Leds for parking lights and brake, i leave the bulb for the turn signal, that because the orgininal tail light use three wire for each function, Parking, Brake and Turn, this tail light have just a hole for a single bulb, so, i put the Leds for two and leave the bulb for the Turn Signal... look realy great, i am using too white Leds for Reverse... And in the front too...
__________________
  #14
Old 06-19-2006, 05:56 PM
FYI, I am waiting for the Red orange LED's to be shipped from Future Electronics...I have recieved the drivers and await go time!
  #15
Old 07-05-2006, 09:50 PM
FYI Amber Lux's came in today. I will be testing them out tomorrow after I get them hooked up to the driver. I will post some pictures when I have an idea of what will happen
Does anyone have any reccomendations before I get started?
  #16
Old 07-06-2006, 08:59 AM
Changchung's Avatar
remember, the car when is runing drive 14.4 volts, if you need make some calculate make with 14.4 volts... not 12... good luck
__________________
  #17
Old 07-06-2006, 02:06 PM
Shrug Re: LED Conversion in Tail Light, Updated ?'s
Well, the first try at it kinda sucked.
I put 3 Amber Lux III's in a triangle pattern, connected them in series, and then wired them up to a CC5W Driver from TaskLed.com
At first look inside, it looked like it may work well, however when I got it outside and paired it against the other signal, the LED one looked horrible!
I am back inside, and would love any sugesstions people may have!
Thanks!
-Eric
  #18
Old 07-06-2006, 03:36 PM
Default Re: LED Conversion in Tail Light,Problems 7-6-06
I did notice when I Drive only 1 of the stars with the driver it is much brighter than the 3 in series...obviously becuase of the power loss since I am driving 3 rather than 1....
I am also afraid I may have "cooked" one of the stars, it is still pretty bright, however the clear lens on it has become a bit clouded than the others....any thoughts?
Thanks guys!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
