CandlePowerForums
CPF Only
User Name
Password
Register
HDS Systems
Reply
Thread Tools Display Modes
  #1
Old 06-12-2006, 08:37 AM
pedalinbob's Avatar
pedalinbob pedalinbob is offline
Default Solar LED outdoor lights
We purchased a couple of those little solar-powered LED outdoor lights.
They are made by Brinkmann, have a white LED and a solar panel.
They came with NiMh AA bats.
What is interesting, is that they run on a single AA, so they must have a step-up of some sort. Pretty cool.
Here is the question: The stock bats are only 700mah. Should I replace them with a bat with greater capacity?
Could it be that the lower capacity allows deeper discharge, therefore conditioning the battery more? I did condition the new bats in my Vanson prior to installation.
Thanks,
Bob
  #2
Old 06-12-2006, 09:07 AM
Tritium's Avatar
Tritium Tritium is offline
Default Re: Solar LED outdoor lights
I have some of the solar lights from True Value Hardware. Mine came with 600mah nicads. They would only last about 4 hours past sundown. I replaced them with 2400mah NiMh and now they run all night.
Thurmond
__________________
Resistance is Futile. You Will be Modded!!
Infinity (CMG that is) and Beyond!!
  #3
Old 06-15-2006, 02:23 PM
eluminator eluminator is offline
Yep, I just got two Westinghouse brand. They have a single 600 mah NiCad. I'll see what they do. I've successfully replaced NiCad with NiMH before in lights that used two AA cells.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
