As the topic says, what do you guys think about putting Osrams Halostar IRC-lamps in car/motorcycle headlights? For example, I have a bike with a BA20D 12V 45/40W headlight, and "high speed" driving at night is out of the question. Going over 70kph/45mph means that you don't have much of a chance to stop before you run into whatever might be on the road ahead...
Using a 60W lamp is probably not possible, they are hard to get and I doubt that there is enough power available to drive it, and the 35/35W halogen light that is even worse to get will probably not be any better than the 45/40W incandescent I am using now. My idea is to throw out the ordinary lamp and make a 50W Halostar IRC fit, there should be enough power available to drive it and as it is supposed to give as much light as a 75(?)W ordinary halogen it would probably mean that I get almost twice as much light compared to the lamp I have now.
The downside is that I won't be able to keep the high/low beam, but if the light gets so much better that is something I can live with...
Don't know about oncoming traffic though, but on the small twisty roads I usually drive I generally never meet anyone anyway.
On cars with H1/H3/H7 lamps or similar it should work great too (or would it?). Drawing just about 55W at 13V it will use the same amount of power as the standard lamps so there is no risk of burning the reflectors, but it should give quite a bit more light. And longer life too if my memory serves me correctly, i think the carlamps have a life of just a few hundred hours and the IRC should last a few thousand at the same voltage...
So, anyone have any thoughts about using the IRC-lamps on the roads? There probably is a reason Osram don't sell IRC H7-lamps etc, but I can't figure it out now. (Could it be that they are developing them as we speak, or would they not be so much better than the Silver Star lamps?)
