Re: Has anyone used Lux3 1157 taillight from superbrightled.com?
I'm using them on my E36.
I've got citylights wired in, so I've got a piece of electrical tape over the low wattage pin on the base. Basically converting them to 1156's.
The difference between low and bright isn't staggering, and they'll not shine behind them to the reflector back.
I'd only recommend them if you've got stock turnsignal housings with a textured outer lens. if you've got a clear outer lens, it'll look like there is a single point of light, and you'll suffer for visibility.
i like the lamps for the instant on, the brightness, and the fact that I no longer have the "egg yolk" effect in my lenses.
