Re: simple flourescent question
Could it be the ballast (the little cylinder thing)?
Sounds like your switch-starter is bad. The "little cylinder thing"- is this the removable plastic thing that pokes out of the side, with 2 little metal lugs on the bottom? That`s your starter- I`d replace that and see how it goes. Find one at your local electrical/hardware store. Don`t turn that thing on again till you do, as it can cause damage to the new tube, and the ballast (which is a lumpy rectangular metal thing inside) if left with just the ends glowing.
Hopefully it`ll spring back into life, but if not, possibly the ballast needs changing too. In this case I`d just buy a new fixture, they`re cheap enough.
[img]images/icons/grin.gif[/img]
