CandlePowerForums
CPF Only
User Name
Password
Register
Peak LES
Reply
Thread Tools Display Modes
  #1
Old 05-06-2002, 07:26 AM
rigormootis's Avatar
rigormootis rigormootis is offline
Default Why I love my CM3
Here's why.
First thing to note is that I also have an e2e, M2, and a host of other lights (Arc-CPF edition, (2) Inova X5s, a few CMG Infinities (2nd Gen.), Streamlight Pro-Polymer 3C Police (with some Write-Right film to imporove the beam), PT Tec-40, PT Matrix, some Photon IIs, etc...(to name some of my favorites). [img]images/icons/wink.gif[/img]
However, this post is about why I love my "frankenlight" that is my CM3.
<UL TYPE=SQUARE><LI>It's Type-III Hard Anodized.
<LI>The M2 bezel (on a CM3) is shock isolated, has a Pyrex lens, and uses P series LAs (so you only need SC1s if all you have are M2, CM3, and E2e lights).
<LI>The 25 Lu you give up from the M3 is marginal (IMHO). (A CM3 takes the P90 or P91 HOLA giving you 105 or 200 Lu respectively).
<LI>You can add an extra O-ring to the LOTC that comes with the newer C3 body to make your CM3 as waterproof as an M2.
<LI>If you already have an M2 (like I did when I bought My CM3), you can use all your M2 filter caps interchangeably (a very nice perk).[/list]
The only reason I can see to go with an M3 (for example) over a CM3 is if you want a shock isolated Turbo head...I for one do not. For the times I "need" the ultra-long reach that a regular M2 head (on my CM3) + p91 doesn't provide (these opportunities are VERY rare for me), I'd prefer a M4 or M6 to a M3T anyway.
Final disclaimer, my choices of light are often predicated on the following things: light output, waterproofness, shock-isolation, beam quality, and run-time (not always in that order). For those who don't care about shock-isolation (for example), I am surre there are other (cheaper) options out there for you. However, for operators who need these things, I think that a CM3, M2, or M3 is the way to go.
Let the comments begin...
[img]images/icons/grin.gif[/img] [img]images/icons/cool.gif[/img]
  #2
Old 05-06-2002, 08:42 AM
bwcaw bwcaw is offline
Default Re: Why I love my CM3
How did the o-rings that i sent you work out?
  #3
Old 05-06-2002, 08:59 AM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Bigwuss:
How did the o-rings that I sent you work out?<HR></BLOCKQUOTE>
Oh yes....a BIG thank you to "Bigwuss" for some extra o-rings!!!
BW, they work just great!!! After sacrificing 2 of them (once I got them on, I couldn't get them back off without cutting them), I found that the only way to use them (at least on the C3 body) is to place them in the forward-most recess on the tail-cap end (and the SF one behind that). Otherwise, the extra girth of the o-rings you sent prevents me from tightening the LOTC enough to activate the constant-on feature. I have not tried them on the bezel end or on my E2e...but I assume that they should work well on the bezel ends of both my M2 and CM3 when I need to replace the existing o-rings. Perhaps, because they fit tighter, they will add some "extra' water resistance...(?).
Thanks again!
  #4
Old 05-06-2002, 10:07 PM
Hey, i am glad you like them! my fingers hurt for about two days after i tried to
put some of those on my M2. [img]images/icons/grin.gif[/img] BTW the
v72 is working out fine. I really like the
ability to draw my M2 in one easy motion.
Thanks! [img]images/icons/grin.gif[/img]
  #5
Old 05-08-2002, 06:05 AM
Mr. Blue Mr. Blue is offline
I use a C3 w/ M2 bezel as well and think highly of its form and function. 105 lu. for 60 mins is ok with me..What is a CM3? is that the same as a C3?
  #6
Old 05-08-2002, 09:43 AM
I call my C3 + M2 bezel a "CM3".
  #7
Old 05-08-2002, 07:35 PM
Here's a good pic / discussion of the "CM3."
http://186thousand.com/cgi-bin/ultim...c;f=9;t=001370
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
