CandlePowerForums
CPF Only
User Name
Password
Register
Reply
Thread Tools Display Modes
  #1
Old 08-26-2002, 07:21 PM
jbechto jbechto is offline
Default Solar pathlight Problem...help!
Two of my Siemans solar path lights are exhibiting a peculiar problem.
When I turn them on, they stay on very briefly (1-10 seconds) then blink off. The battery voltage is fine (2.6 volts for the 2 NiCds) and does not drop much with the light on, so I think the batteries are fine. After they turn off, they will not turn back on immediately by themselves or manually, but if I let them sit a few minutes in the off position, I can sometimes get another few seconds of light when I turn them back on. Sometimes they just won't go back on.
Anyone had this experience or know what could be wrong?
These darn things were expensive and I'd like to get them going again!
I will post a photo of the circuit board later tonight.
Thank you!
John
  #2
Old 08-26-2002, 09:46 PM
Default Re: Solar pathlight Problem...help!
OK here it is. Any help would be greatly appreciated.
The RED & BLACK wires go to the solar cell, the BROWN & YELLOW, to the light sensor, the ORANGE& WHITE to the manual off switch, and the WHITE & BLUE up to the bulb.
Thanks for looking!
John
  #3
Old 08-26-2002, 09:51 PM
Saaby Saaby is offline
Mostly MIA Administrator
Quote:
Thanks for looking!
<font size="2" face="Verdana, Arial">What is this, an eBay auction [img]images/icons/wink.gif[/img]
You know, the counters at the bottom of the page...
  #4
Brocken Brocken is offline
try covering the photo cell up, I had a problem with some cheap lights like this that wouldn't turn on even with it was dark outside because there was enough light around to keep the photo cell from activating them. Maybe they turn on and then turn each other off with their light. I just glued a small piece of dark plastic sheet over the photo cell and also lowered it down inside of the housing some more.
dave
  #5
Old 08-27-2002, 03:11 AM
I've got a X10 motion sensor in my room, they can operate in several different "modes" if you will. One involves light/dark...there's a photocell in the motion sensor to control this. A popular "mod" if you will is covering this up, shrinkwrap tubing is a popular way of doing it.
  #6
Old 08-27-2002, 08:32 AM
axolotls axolotls is offline
The newer X-10 Motion sensors... You don't need to cover up the photocell. They have an additional option for always detect or dusk/dawn
  #7
Old 08-27-2002, 12:54 PM
Quote:
<font size="2" face="Verdana, Arial">Or so they'd have you think...I don't remember the exact reasons but some people still feel compelled to cover the photocell even on the new ones.
  #8
Old 08-27-2002, 01:14 PM
Thanks for the replies and ideas.
Nope, the photo cell isn't it. I tried covering them up (completely!) and there is no change. I did notice that replacing the bulb with a kernel bulb from a Mini-Mag(tm) (brighter, more draw) makes them go out even more quickly. Something strange is going on on that little PC board!
I'll keep on checking.
  #9
Old 09-01-2002, 08:36 AM
snakebite's Avatar
snakebite snakebite is offline
how old?
how much does the voltage drop when on?
how much current does the panel supply to the batts in full sun?
if well designed they will shut off at a voltage that ensures that the nicd's will not be overdischarged.that may be what is happening due to not charging or worn out batts.
  #10
Old 09-17-2002, 01:49 PM
star882's Avatar
star882 star882 is offline
Try to trace out the schematic.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
