CandlePowerForums
CPF Only
User Name
Password
Register
4Sevens
Reply
Thread Tools Display Modes
  #1
Old 12-09-2002, 01:34 PM
Zelandeth's Avatar
Zelandeth Zelandeth is offline
Default Building a light-meter...maybe
Basically a simple question here. Having found a phototransistor (I think, as the current induced seems to be directly proportionaly ot the light level), would it be possible to actually build my own light-meter. I assume so, as the current reading on the multimeter would be proportional to the light level - in theory. Main thing I'd need would be at least two reference points to create a scale. So, what should I look for as these reference points? i.e. a 60W candescent of a given design having a specific output, and a 100W one a known value as well, and using these vales to "calibrate" the scale. Could this be done?
Zel.
  #2
Old 12-09-2002, 02:30 PM
Doug S Doug S is offline
Default Re: Building a light-meter...maybe
The response function of most photocells and phototransistors as a function of wavelength is very different from the human eye. They are typically most sensitive to wavelengths that are not even light. Photocells that are used to measure light are equipped with special filters to correct their response curves to match that of the human eye.
  #3
Old 12-12-2002, 05:50 PM
Zelandeth's Avatar
Well, it was at least an idea worth investigating. Even though it's a non-starter; at least unless I can find the datasheets that should have come with the unit.
Thanks for the info,
Zel.
  #4
Old 12-12-2002, 10:40 PM
INRETECH INRETECH is offline
The device also may not be linear in its sensitivity
Most lightmeters have special sensors and correction hardware/software to correct for this
  #5
Old 12-14-2002, 08:28 AM
Albany Tom Albany Tom is offline
These guys are right. However, with enough time and playing around, you could have something usefull anyway. You could use this to compare two different lights with similar spectral output, like 2 different LED lights. You could play with using photographic filters to tune your sensor to closer to human vision. A UV and IR blocking gel filter would be a good start.
Finally, you could use your sensor as is to measure the brightness vs runtime of almost any light, as Roy has done with his great runtime graphs. To get rough calibrations for brightness, you could use 2 or 3 identical lights superimposed on each other, or even better with some neutral density photo filters.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
