CandlePowerForums
CPF Only
User Name
Password
Register
Wicked Lasers
Reply
Thread Tools Display Modes
  #1
Old 09-24-2006, 09:24 PM
yuandrew's Avatar
yuandrew yuandrew is offline
Default Building a 12 volt light
I have an old desk lamp laying around that originally uses a strange 120 volt 40 watt bulb with a base that is larger than a night light but smaller than a regular medium based bulb. The bulb had burned out a long time ago but I decided to put that old lamp to use on a 12 volt electrical system. I cut the plug off and replaced it with an Anderson Powerpole connector then removed the original socket.
I'm thinking about using a MR16 bulb in it but does anyone know where I can find a bi-pin socket that would have a screw going down the middle to secure it to a metal "L" bracket ?
I'm currently using a bayonet based 12 volt RV bulb (I think around 28 watts) which is actually soldered directly to the wires and just hangs inside the lamp shade. Primary use will be a task lamp.
I had though about using high powered LEDs at first but didn't have the budget for a quanity that would produce the light output I wanted. BTW, anyone know the light output I would get from a 20 watt MR16 ?
  #2
Old 09-25-2006, 12:42 AM
hotbeam's Avatar
hotbeam hotbeam is offline
Default Re: Building a 12 volt light
20w MR16 does about 225lms ±
  #3
Old 09-25-2006, 12:51 AM
DonShock DonShock is online now
Although it doesn't have a single mounting hole in the center, if you think you can make this socket work, I can send you one for free. I am using one to run an MR16 in a mag head off a SLA 12v battery. Just PM me your address.
  #4
Old 09-25-2006, 11:41 AM
yuandrew's Avatar
That may work, the holes are near the edge but I won't mind the bulb being a little off centered. If that is 225 lumens; maybe two or three K2s would work later when I have the time and budget to go LED.
  #5
Old 09-25-2006, 06:19 PM
yuandrew's Avatar
Message Sent; Thanks.
  #6
Old 09-25-2006, 08:23 PM
Ken_McE's Avatar
Ken_McE Ken_McE is offline
I believe you could put a small metal hose clamp around the outside of that fixture and gently tighten it onto a metal rod. If that rod is threaded, you're all set.
  #7
Old 09-29-2006, 07:23 PM
yuandrew's Avatar
It arrived today; thanks Don
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
