CandlePowerForums
CPF Only
User Name
Password
Register
Reply
Thread Tools Display Modes
  #1
Old 10-06-2006, 05:37 PM
Dustin Liu Dustin Liu is offline
Banned
Default How many lumens?
How many lumens is the sun?
Seriously
I really want to know.
  #2
Old 10-06-2006, 07:00 PM
Illumination Illumination is offline
Default Re: How many lumens?
Lumens is a measure of total light output...the total light output of the sun is simply not worth comparing to any hand held flashlight. The sun lights up half the earth, the moon, and the rest of the planets in the solar system, etc. That is like comparing the weight of a grain of salt to the weight of the earth. Maybe that is what you are looking for...but I'm not sure why.
Or are you trying to compare brightness of sunlight versus the brightness of a flashlight on a particular object (e.g., a light meter). Then you should be comparing a measure of brightness, like lux (which is defined as lumens per square meter), of one versus the other.
Of course, you are then going to have to think about how far away the light will be held from the object you are illuminating. Lets first think about the brightness of flashlights. The Throw measure on Flashlight Reviews Throw and Output Table shows the distance (in meters) a given light throws 1 lux. You can then use the inverse square law to figure out brightness at a given distance. The formula would be Brightness (in lux) @ Distance (in meters) = (1/ (Distance/Throw) )^2.
For an example, according to throw and output chart, the Surefire A2 Incan throws 45. Using the inverse square law, that light has a brightness of 2025 Lux at 1 meter.
To compare it to sunlight, look at this table I found this table on the internet:
Brightness Values:
Candle light at 20 cm 10-15 Lux
Street light 10-20 Lux
Normal living room lighting 100 Lux
Office fluorescent light 300-500 Lux
Halogen lamp 750 Lux
Sunlight, 1 hour before sunset 1000 Lux
Daylight, cloudy sky 5000 Lux
Daylight, clear sky 10,000 Lux
Bright sunlight
> 20,000 Lux
So...an A2 at it's brightest spot shining at something one meter away is about half as bright as sunlight on a cloudy day. This seems reasonable - remember at night flashlights look so bright because everything else is dark and your eyes adapt.
__________________
I spend my days in the light thinking about flashlights in the dark
  #3
Old 10-07-2006, 02:46 AM
ringzero ringzero is offline
Quote:
It's fairly straightforward:
1) Look up the Sun's total output in Watts. I've seen the figure, but don't remember offhand.
2) Look up the percentage of the total ouput that falls in the visible light part of the spectrum.
3) Calculate the visible light output of Sun in watts by multiplying 1) times 2). Maybe you can find this figure somewhere and skip the first two steps.
4) Last step: convert Watts to Lumens.
  #4
Old 10-07-2006, 06:05 AM
winny winny is offline
~3.75×10^28 lm according to wikipedia.org
link
__________________
Still no response to that PM or e-mail you sent me two months ago? Try sending it again. I'm terrible at keeping track of messages.
  #5
Old 10-07-2006, 08:15 AM
Gnufsh's Avatar
Gnufsh Gnufsh is offline
Only a very tiny fraction of the light from the sun hits the earth, or any planet at all for that matter. The vast majority just heads off into space.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
