10-07-2006, 06:14 PM
LED Tea Candles
Here is a recent LED find while grocery shopping with my wife. These are LED tea candles. They run off a single CR2032 and claim a battery life of 40 hours. They have a very realistic flicker and seem to work quite well. Cost was less than CAN$6 for two. We picked them up at Loblaws grocery chain. Here are the pics:
packaging
"specs"
battery compartment
with the cover off
3mm amber LED on
"Beamshot"
No matter how bright it is, I guess the output would be 1 Candlepower.
Paul
10-07-2006, 08:49 PM
Re: LED Tea Candles
I was looking at those last Thursday. Not a bad deal for the price. Do they flicker at all or just light up?
10-07-2006, 10:02 PM
Re: LED Tea Candles
Quote:
They flicker. Pretty realistic too.
10-08-2006, 10:09 AM
Re: LED Tea Candles
How bright are they? I think these might be good for Jack-O-Lanterns.
10-08-2006, 12:05 PM
Re: LED Tea Candles
Quote:
They are fairly close to tea candle brightness.
Paul
10-09-2006, 11:32 PM
Re: LED Tea Candles
Quote:
Paul
ER, no they aren't... I've got some of them ($7 for 4 at Fry's) and while they are cool for romantic picnics at the Hollywood Bowl, they aren't as bright as an actual tea light. I'd say about 8 to 16 of these to equal the output of one regular tea light.
10-10-2006, 04:45 AM
Re: LED Tea Candles
Quote:
Perhaps we have different models. I haven't compared them side by side, but the ones I have are a decent substitute for a real tea candle.
10-14-2006, 08:54 AM
Re: LED Tea Candles
10-14-2006, 11:16 AM
Re: LED Tea Candles
Nice comparison Paul, with Halloween 2 weeks away these could be good for lighting up pumpkins (excuse to buy them  )
10-25-2006, 01:51 AM
Re: LED Tea Candles
Real candles have considerable variability of output, depending on how short you cut the wick -- as much as 2 or 3 stops. with a short enough wick, you can get the candle down to within a stop of the LED.
Apparently you run yours to spec, while I overdrive mine
Here's a sample... to the right on the wine bottle is a small flame (not quite as small as yours is I don't think), in the middle are four LED teacandles, and an "overdriven" votive is on the left (it's flame is about an inch tall, perhaps a bit more). All at about the same distance to the neutral-colored wall.
10-25-2006, 01:56 AM
Re: LED Tea Candles
Isn't this nice? We are finally having a cooperative effort from members of the CandlePowerForums and the CandleForums!
__________________
RadarGreg
"If you can read this, thank a teacher. If you can read this in English, thank a Soldier. If you can read this in the dark, thank a Flashaholic."
10-25-2006, 04:46 AM
Re: LED Tea Candles
I forgot to mention that my candle was "stock". No wick cutting.
11-23-2006, 04:16 PM
Re: LED Tea Candles
Similar tea lights are sold locally for $2 each and use a CR2450 cell. New cells are available from Amondo Tech for $0.75. They flicker but must be less efficient at only 40 hours of rather dim light compared to the 2032 cell type.
__________________
I'm absolutely certain that I need another flashlight.
12-03-2006, 06:23 PM
Re: LED Tea Candles
Dollar Tree stores in the U.S. have some for a dollar, oddly enough.
They run on a single 2032 battery. Externally they look similar to the one chimo posted, internally the board is smaller and the battery is centered in the base. I found them in a cardboard display near the front of the store.
12-03-2006, 06:55 PM
*Flashaholic*
Re: LED Tea Candles
That comparison was performed with red glass. The "real" candle has a broadband-ish spectral distribution with a fair amount of output in the red wavelengths, but LEDs are quite monochromatic. I doubt that there's much red content in the amber LED in the electronic candle, so that has to be taken into account when comparing brightness. If those were amber glass candleholders, the LED would probably appear considerably brighter than it did behind the red glass.
12-03-2006, 11:45 PM
Re: LED Tea Candles
Do the Dollar Tree ones seem similar in brightness to the ones posted here?
12-04-2006, 08:50 AM
Re: LED Tea Candles
I got one from Dollar Tree last week, and it's not bright at all. Definatly not as bright as a real tea light. But it's kinda nice to turn on and fall asleep next to.
__________________
RIP Don and Mike Show. Long Live The Mike O'Meara Show!
12-04-2006, 10:34 AM
Re: LED Tea Candles
I have some of that style, but I dont like the fact that the batteries are NOT cheap, and they dont last long. I picked up some 2xAA window 'candles' from Menards. they run for 8hrs (from switched on) then they 'sleep' for 16hrs. I am reworking the setup so the 2xAA batteries lay next to each other and the LED and driver will be on top. I have some wall sconces that look nice with the LED lights (oh, they flicker too with amber LED). will try and get some pics when I get them finished.
Jeff
__________________
"We cannot learn from one another, until we stop shouting at one another, until we speak quietly enough, so that our words can be heard, as well as our voices." R.M.Nixon 1969
12-04-2006, 02:43 PM
Re: LED Tea Candles
Could you just snakes 2 leads out of the tea lights and run them on a CR123? I was thinking of trying this when the 2032 dies. The runtime would be alot better.
__________________
12-04-2006, 04:48 PM
Re: LED Tea Candles
The flickering lights that I got, which look similar to chimo's, draw about 10 - 15 mA from the 2450 cell when new. The 2032 cells can be had for much less than the 2450's so his may be a better find and, except for not having to change cells as often, it may not pay to use a CR123. Of course, the 123s might keep the light brighter. The lights I have will continuously run for many days but are barely visible after about 40 hours.
__________________
12-09-2006, 01:24 PM
Re: LED Tea Candles
My brother gave me a bunch of 2032 batteries so I was glad to find something to use them in. The base comes off the Dollar Tree lights by prying it and the board and LED usually fall out. The LED is soldered at the edge of the board and the leads are bent 90 deg. to orient it. If I get a few battery changes out of 'em before they die I'll be happy.
Hmmm, I wonder how long they would run on 2 2016 batteries, and what if I put an MJ LED in it,and...
12-11-2006, 08:16 PM
Re: LED Tea Candles
OK, I got the 'candles' modded, and they work GREAT in the wall sconces.
Now.... the pics.
Here is the candle un-modded
Front of PCB
Back of PCB
PCB taped to battery holder, LED repositioned and 'frosted' with sandpaper.
Full pic
The battery holder is a 3xAA, I just jumpered the center cell position out. The effect is really nice. the timer is great, on at about 5:00 and off just after midnight. I should have to replace the cells every month or so (got a bunch of CHEAP-O AA's)
Cheers
Jeff
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
