CandlePowerForums
CPF Only
User Name
Password
Register
Reply
Thread Tools Display Modes
  #1
Old 10-07-2006, 10:50 PM
NewBie's Avatar
NewBie NewBie is offline
*Retired*
Default Germicidal UV bulbs
I'm looking for something like this product, does anyone know where to get them at a lower cost?
http://www.donsbulbs.com/cgi-bin/r/b...traviolet.html
__________________
I exist, therefor I am!
a.k.a. Jarhead
http://jarhead.hobby-site.com/~jarhead/led.html
http://www.molalla.net/~leeper/led.htm
  #2
Old 10-08-2006, 02:50 AM
Handlobraesing Handlobraesing is offline
Banned
Default Re: Germicidal UV bulbs
Quote:
http://www.donsbulbs.com/cgi-bin/r/b.pl/gph%7C254mm%7Ct5%7Cvh%7C2pin~atlantic-ultraviolet.html
Have you called Pacific Lamp Wholesale in Beaverton? By similar, I'm not sure if you need the size and type in the example or a germicidal lamp in general.
G15T8 in standard 15W T8 shouldn't cost more than $40.
  #3
Old 10-08-2006, 10:07 AM
Ken_McE's Avatar
Ken_McE Ken_McE is offline
I don't see the part where he specifies output in Nanometers.
  #4
Old 10-08-2006, 10:47 AM
NewBie's Avatar
*Retired*
The wavelength is short enough that it produces ozone as I understand it, and it uses a quartz envelope to allow the "short" UV thru, which normal glass blocks.
Going by memory, I believe it was 265mn or 290nm, but I don't recall now.
__________________
a.k.a. Jarhead
  #5
Old 10-08-2006, 11:47 AM
PhotonWrangler's Avatar
PhotonWrangler PhotonWrangler is offline
*Flashaholic*
The newer germicidal envelopes claim to filter out most of the ozone-producing wavelength while allowing other germicidal wavelengths to escape. I believe the older quartz bulb envelopes produce more ozone.
BTW I agree with Handlobraesing; you shouldn't pay more than $40 for one of those lamps. The last time I purchased something like that from bulbs.com it cost me around $35.
__________________
The future ain't what it used to be.
  #6
Old 10-08-2006, 03:30 PM
Banned
The usual germicidal bulb is ~250nm, but if you're using it to make ozone, you need something made with glass that passes ~185nm.
Most germicidal lamps are designed to not let 185nm out to avoid ozone.
  #7
Old 10-08-2006, 07:44 PM
NewBie's Avatar
*Retired*
No Duh.
Thats why i was talking about quartz.
However, there are some special glasses better suited, but highly expensive. I really don't need you to explain this stuff to me.
Since you appear to be knowledgeable about bulbs, could you actually point to a 14W bulb that is lower cost, that will pass wavelengths which produce ozone?
So far your examples have been useless to me.
Typically low pressure argon is used to stimulate the mercury vapour. It is this process which generates ultra violet radiation mainly at 253.7nm (germicidal) and shorter wavelengths (such as 185nm- ozone producing). Atypically quartz is used, as it passes the UV light better than other similar cost glasses. The choice will vary depending on which wavelengths you really want.
Often with these sorts of lamps, they are mis-represented as hard quartz, and one can see the soft quartz that was used, turning black itself, not from deposits inside.
"Fused Silica" aka quartz, comes in several grades. One that would pass 185nm well is known as Full Spectrum Grade Synthetic Fused Silica (KI), a plot is shown here:
http://www.sciner.com/Opticsland/FS.htm
__________________
a.k.a. Jarhead
  #8
Old 10-08-2006, 10:42 PM
Banned
No Duh.
What about this one? $35
http://www.1000bulbs.com/product.php?product=3997
  #9
Old 10-08-2006, 10:52 PM
NewBie's Avatar
*Retired*
That works, thanks.
__________________
a.k.a. Jarhead
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
