CandlePowerForums
CPF Only
User Name
Password
Register
Reply
Thread Tools Display Modes
  #1
Old 10-13-2006, 01:06 PM
n3eg n3eg is offline
Default Continuous duty white LED for backlight?
Is there a better way?
These things are rated for 10,000 hours, but they dim out at less than 1000.
http://www.sunbriteleds.com/product.asp?id=89
The last one in the list, the white one, is part of a backlight replacement for a Heathkit weather station that used to use a switching supply and fluorescent tube. When the switching supply died, I replaced it with a series/parallel array of these white LEDs powered by a 26 volt DC supply, 3 banks of 2 series LEDs.
Anybody know of a white LED that lasts longer in a continuous duty application, preferably a wedge base or T1 3/4 package and not some expensive die/heatsink photon blaster?
__________________
It ain't easy being me, but someone's gotta do it.
  #2
Old 10-14-2006, 05:57 AM
Wim Hertog Wim Hertog is offline
Default Re: Continuous duty white LED for backlight?
I would use Nichia SMD LEDs (http://www.dotlight.de/shop/product_...roducts_id/432) . If you drive them at 10mA or less they should last 50 000 hrs without significant dimming.
Also, a wide viewing angle makes it easy to backlight the LCD.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
