CandlePowerForums
CPF Only
User Name
Password
Register
4Sevens
Reply
Thread Tools Display Modes
  #1
Old 10-21-2006, 06:24 PM
gholco gholco is offline
Unenlightened
Default LED nitelite for Box
I've been requested to place a LED type light into a telescope eyepiece case that allows the user to open the case and the LED light switches on, he can select the next epepiece, close the lid and the light switches off.
Can anyone direct me to the best source/option for such a contraption?
Thanks,
Gary
  #2
Old 10-22-2006, 10:19 PM
Melchior Melchior is offline
Default Re: LED nitelite for Box
Get:
1x REED type switch - normally closed.
1x Small permanent magnet
1x 2AA/AAA Battery Box
1x Red 5mm LED
1x Resistor 47 ohms (yellow-violet-black)
3x short lengths of wire
The magnet is attached to the front edge of the case; when its closed it keeps the reed switch open, thus the LED is off. It opens and the reed switch closes the circuit.
If you know basic electical wiring you can figure out the circuit yourself.
(just wire everything up into a loop, and pay attention to the LED's orientation -- wrong connection and the LED fries)
The hard part really is building this INTO the case.
Info all around the net:
http://led.linear1.org/
http://www.theledlight.com/ledcircuits.html
http://dansdata.com/caselight.htm
Have Fun!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
