CandlePowerForums
CPF Only
User Name
Password
Register
FoxFury Fire Helmet & Hard Hat Lights!
Reply
Thread Tools Display Modes
  #1
Old 10-27-2006, 01:27 PM
divxdude divxdude is offline
Default need LED resistor help
http://i13.photobucket.com/albums/a2...duude/LEDs.jpg
the red ones in the photo are like 3mm and the rest yellow and green seem to be a tiny 1mm?
so i'm wondering what the volt requirements are
to calculate the resistors needed.
i know some leds are as low as 1.8v so i dont want to cook them.
i will be using single LEDs in parellel with a resistorfor each
the par. array formula for a 13.4v supply
with different volt drops on the LED at a safe 17mA.
R = (13.4 - 1.85) / .017 = 679
R = (13.4 - 2.00) / .017 = 670
R = (13.4 - 2.40) / .017 = 647
R = (13.4 - 2.80) / .017 = 623
so what volts do 1mm LEDs from a couple years ago use? these are from a surplus store and may be several years old.
and am i doing the math right?
  #2
Old 10-27-2006, 11:27 PM
EvilLithiumMan's Avatar
EvilLithiumMan EvilLithiumMan is offline
Default Re: need LED resistor help
Your math is dead on, no problem there. Most red LEDs of that size are typcially 1.7-1.8 volts. Naturally, once you get your particular LED, you'll be able to measue the actual Vf.
I wouldn't worry too much about "cooking" the LED. Putting 30ma through a 20ma will degrade it's total life, but it won't "cook" it. I've played around a lot with LEDs and have run 100ma through 20ma rated devices for many continuous hours without a failure.
And just last week, I put a RGB flashing LED into a PR2 socket for use in a flashlight. The design spec on the LED is a Vf of 3.4v at 30ma. But I used only a 10 ohm limiting resistor as I wanted maximum illumination and know the kid will only run the light a few minutes at a time. I put 4 new alkaline cells into the host and let it run for four days (96 hours). 6 volts - 3.4 = 2.6 volts, limited with a 10 ohm resistor is a whopping 260ma. I thought for sure the LED would smoke in a few minutes, but it did the entire run. (Obviously, the cells weren't at 6 volts after four days of running. I wish now I had measured the voltage before handing the light over, but it was still quite bright).
__________________
SF G2+KT1, C3, E1E. SL Poly Stinger. Arc LSHF-P. MagCharger, AA MiniMag w/ MM+WO LIII S. PT20. PT40. S&W FL10. Etch-A-Sketch. Mister Microphone.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
