CandlePowerForums
CPF Only
User Name
Password
Register
4Sevens
Reply
Thread Tools Display Modes
  #1
Old 11-02-2006, 02:07 PM
FrogsInWinter FrogsInWinter is offline
Default UV light transmittance?
Does anyone have any measurements on UV light transmittance through various lenses? Specifically comparing polycarbonate, lexan, pyrex, borofloat, B270, mineral glass, or UCL to the bare LEDs. From what I've read on wikipedia, glass is more transparent to UV light while polycarbonate inherently blocks most UV light.
I'm going to drop a UV TerraLUX Ministar 2 into a 2aa mini-mag and I'm wondering if there's a big difference between UV light transmittance vs. visible light transmittance through different lenses. After all having a UV LED behind a lens that blocks most/all UV light doesn't make a whole lot of sense.
Would it be a better idea for me to get a UV light that has the LEDs exposed? Like the ones sold on Light Hound or Advancedmart? Thanks in advance for any helpful information!
__________________
"I hate quotes. Tell me what you know." -Ralph Waldo Emmerson
Greg at Brightguy.com rocks! Thanks for all the great service.
  #2
Old 11-02-2006, 02:25 PM
macforsale's Avatar
macforsale macforsale is offline
Default Re: UV light transmittance?
  #3
Old 11-02-2006, 03:33 PM
Sub_Umbra's Avatar
Sub_Umbra Sub_Umbra is offline
Quote:
Originally Posted by FrogsInWinter
Does anyone have any measurements on UV light transmittance through various lenses? Specifically comparing polycarbonate, lexan, pyrex, borofloat, B270, mineral glass, or UCL to the bare LEDs. From what I've read on wikipedia, glass is more transparent to UV light while polycarbonate inherently blocks most UV light...
I don't have any measurements. I'd like to see them, too.
While glass itself may block less UV than other materials, I've read that the AR coatings on UCLs attenuate UV and are counterproductive in that use.
IIRC InReTech used to advise customers to use M/\G's stock polycarbonate window with their UV drop-ins. I'm not sure, though.
Some CPFers have noted that the Carlco optics tend to attenuate UV while the Frean optics do not. They have stated that a visibly noticable color change in the UV beam will accompany this attenuation. (The Carclo optics glow green instead of purple.)
If you do find any hard data on UV transmission rates with various materials be sure to post it. It's a very interesting subject.
  #4
Old 11-02-2006, 04:25 PM
elgarak's Avatar
elgarak elgarak is offline
As a rule of thumb, glass DOES NOT transmit UV. Period. That's the rule that I as physicist use. All glasses that do are specially formulated (and are technically not glasses, but look and feel like it). You will know it when you buy it, 'cause it's frickin' expensive.
Now, LEDs are just barely in the UV. Mostly they emit around 400nm, which is near UV purple. I have seen flashlights emitting ~375 nm. Bare LEDs may go down to 350nm. That's all just beginning of UV, so most glasses MAY work. However, I would recommend using LEDs bare, especially the lower wavelength ones, since they are probably not very bright yet, so you wanna avoid any absorbance.
  #5
Old 11-02-2006, 04:44 PM
cdosrun's Avatar
cdosrun cdosrun is offline
Absorption at UV wavelengths is worth noting, but I don't think it is too much of a problem with the longer wavelengths as Elgarak noted. Nichia do use quartz 'glass' on their focused UV leds as quartz has very low attenuation in the UV spectrum.
Optical glass should be good to around 335-350nm, Acrylic down to about 300nm and quartz, well into the UVc range (140nm or so). An idea is probably to Google for something like "acrylic cuvettes nm" substituting acrylic for the material in question. Cuvettes are the little receptacles for samples when measured spectrographically in the lab.
  #6
Old 11-02-2006, 05:03 PM
soapy soapy is offline
Agreed. The "UV" is generally visible purple light and very long wavelength UV, which glass will let through just fine.
Do tests on anything neon at a bit of a distance, and use the return from your neon target to tell you if anything much has been cut out when you add your test material.
__________________
4.5mW 532nm, 45mW 532nm, 3mW 670nm + dozens of HeNe tubes of many colours, and the LightRat!
EDC = Pelican M1 2310 and Petzl Zipka+
  #7
Old 11-02-2006, 10:38 PM
Sub_Umbra's Avatar
I was thrashing about on the web and I found a few graphics that may have a bit of interesting info here and there. Or not. I added the URL of each graphic to the bottom of each one.
This one isn't big but it's too wide for this page.
I know that this stuff isn't particularly pointy but I thought it was interesting enough to put up.
  #8
Old 11-02-2006, 11:35 PM
NewBie's Avatar
NewBie NewBie is offline
*Retired*
Also check this out:
__________________
I exist, therefor I am!
a.k.a. Jarhead
http://jarhead.hobby-site.com/~jarhead/led.html
http://www.molalla.net/~leeper/led.htm
  #9
Old 11-03-2006, 01:15 PM
hank's Avatar
hank hank is offline
Are any of the flashlight lens sellers reading this?
If so, please consider sending samples of your various lenses to Craig at LEDmuseum -- he's been posting the spectra of various light sources.
  #10
Old 11-03-2006, 03:59 PM
Wow, thanks to everyone for all the great info. I also posed this question to Chris at Flashlightlenses.com and he gave similar answers to what's been posted here. He was also nice enough to provide me with this chart regarding light transmittance for their UCL lenses:
(Used with permission)
Sorry if the picture is a little small, but you can save it to your computer and zoom in using any kind of picture viewer.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
