CandlePowerForums
CPF Only
User Name
Password
Register
Advertising on CPF!
Reply
Thread Tools Display Modes
  #1
Old 11-07-2006, 06:19 AM
imj imj is offline
Unenlightened
Sigh Burnt smell from H4 halogens
Hi...I just joined this forum today/night . I am having some problems with powering 12v automotive H4 halogens from the mains current....what I do is I use an electronic transformer(11.5v output) for halogen bulbs, those can go up to 60 or 105w but for some reason seems to be overpowering the filaments(I think). After a minute on low beam, the bulb emits a burnt smell...seems to be coming from the black coated tip and I just burnt the silver tip on a 90w/100w HID halogen. Is it normal for this to happen?
IMJ
  #2
Old 11-07-2006, 08:39 AM
tebore tebore is offline
Default Re: Burnt smell from H4 halogens
Well with new bulbs the moment they fire up they create some smell from burning off some production coating and dust.
Does it go away?
  #3
Old 11-07-2006, 03:54 PM
imj imj is offline
Unenlightened
Hi....the 55/60 one has some hours on it and when the wires to it from the transformer is short there will be the smell. The white one 90/100, the smell has gone but after a while I see a burnt area at the silver tip. Btw for the 90/100 I used an Osram halotronic rated at 105w max. Could it be the operating position of the bulb, I operate them horizontal with the low beam reflector facing up.
IMJ
  #4
Old 11-07-2006, 06:11 PM
With Halogens the mounting position shouldn't matter like in the case of HIDs.
I've noticed on some Silver tipped bulbs they get a little "toasted".
I'd check all your wiring again looking for shorts.
  #5
Old 11-07-2006, 06:38 PM
imj imj is offline
Unenlightened
Thanks .
  #6
Old 11-11-2006, 08:51 PM
AutoRoller AutoRoller is offline
Unenlightened
Is there any noticeable degradation in brightness after recharging and using it a few times.
  #7
Old 11-11-2006, 09:00 PM
Handlobraesing Handlobraesing is offline
Banned
You can buy high temperature exhaust manifold paint from stores, but first use and high temperature is part of the curing process. It could be that the black/silver coating on the bulb is similar and uses the bulb's heat for curing.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
