CandlePowerForums
Go Back   CandlePowerForums > Administrative > Practice Posting
CPF Only
User Name
Password
Register
FenixOutfitters
Reply
Thread Tools Display Modes
  #1
Old 02-18-2007, 06:10 PM
abvidledUK's Avatar
abvidledUK abvidledUK is offline
Default TEST. joining of several FS threads and imageshack photo's ok ?
Test to see if withdrawn items can be resurrected at a later date with same imageshack photo's, or do I need to re-load photo's in theh future which would be a pain.
Blue in colour. White LED. Inc Swivel Magnetic clip.
I have four of these, surplus to requirements.
1 Available
2 Available
3 Available
4 Available
I also have three Black ones FS.
1 Available
2 Available
3 Available
Go on, you know you want one...
Only powered up to test. As new.
£6.50 each inc p&p UK.
As alway, first "I'll Take It" gets it.
PM me for Paypal details.
Excellent torches, here's a review of a re-badged one, it's the same torch
http://www.imagometrics.com/FLReviews/Plm4.htm
I have (10) 8 of the original Lambda 4 die SMJLED PR2's which have sat in unused torches now for over a year.
These are the ones:
http://home.mchsi.com/~lambda_lights/pr2bulb.htm
We've had no power cuts this last year, so used for a few minutes each, if that, from new.
I would prefer to sell in pairs, at £5 each bulb, inc p&p to UK
1 SOLD
2 SOLD
3 Available
4 Available
5 Available
6 Available
7 Available
8 Available
9 Available
10 Available
All 8 for £35.
Shipping extra international, it wouldn't be much.
See my posts in other CPF forums to see my opinion, and history of them.
They're a great bulb, I've just installed PIR lights throughout the house.
PM me for paypal info.
This is a very small torch, ideal for modding as it all just unscrews.
Compact size, Water Resistant, Shock Resistant -
Hard anodized finish for extreme corrosion impact
Made of High Quality CNC aluminum
Over 60 Lumens quoted.
Uses 1 x (R)CR123A battery , 3v or 3.6v. Normal CR123 3v also.
Twisty on/off
This is the CR123 version of the popular CR2 light.
Very bright on 3.6V RCR123 , with slight bluish tint.
RT is about 60 minutes continuous with 3.6v RCR123. Fairly constant measured output.
Does get hand hot when on continuously with 3.6v RCR123, with the current emitter, after around 15 mins.
Reflector and lens are plastic. However, the lens does feel like glass, could be glass.
The lens has a not too obvious very fine crack in it, see photo (if you can).
Not visible in beam.
Larger spare lens for cut-down, is supplied.
Tail end has a spring for -ve contact, so no battery rattle when off.
Pill has the same (or similar) emitter as the "Elly" on a round PCB.
Very easy to replace with Cree or Seoul Stars I would imagine.
Asking £5 UK inc shipping.
Torch only. No battery or lanyard.
As usual, first I'll take gets.
Probably next working day delivery to UK.
PM me for paypal address.
I have (originally six) five of these for sale, prefer to UK CPF's, as quite substantial, though compact and portable.
One SOLD, Five remaining.
I will ship abroad, at extra cost.
UK price £10 each inc p&p.
Paypal only, PM me for info. Ta. (pls put CPF name in PP comments box)
Basically, it is an electronic battery tester ( 3xLR44 inc) that measures voltage of AA and AAA cells under load.
The state of the cell under test is indicated by 3 leds
Red, yellow/amber & green.
Red is bad, green is good, yellow/amber...well....
With no cell under test
As you can see from the initial photo, the tester is also designed to carry up to 6 AA's and 4 AAA's. All individually secured and isolated.
The tester automatically switches itself on when cell is inserted for testing, and off when removed.
A good visual indication of battery state.
Appears to work OK with AA lithium (1.7v) cells too, though I cannot vouch for nearly dead indication.
Size is just under 6" x 4"
Weight 160g w/o batteries, around 300g fully loaded.
Brand new, unused, in sealed packaging. Instructions included.
Ideal for those holiday or day out trips.
No AA or AAA batteries included.
(PS: Don't forget to remove LR44 insulation tab before first use. I had to read instructions ! to discover this on mine)
Dorcy 3AAA led torch, with strobe function, £16 to UK inc p&p
http://www.dorcy.com/products.aspx?p=414260
__________________
Batteries, batteries, I need more batteries ........
  #2
Old 02-18-2007, 06:11 PM
abvidledUK's Avatar
Default Re: TEST. joining of several FS threads and imageshack photo's ok ?
Yippee, that works OK.......
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
