CandlePowerForums
CPF Only
User Name
Password
Register
BugOutGearUSA
Reply
Thread Tools Display Modes
  #1
Old 03-03-2007, 08:30 PM
Newuser01's Avatar
Newuser01 Newuser01 is offline
Default Serial connection : 2 shop lights and a switch.
I have 2 shop lights (CFL 4 feet , 2 tubes each) connected to a wall switch in series.
Hot wire -> switch -> cfl -> cfl -> ground back to the ground wire in the switch box (only connect to the wire going back to the fuse panel. not connected to the switch assm.).
Why dose this fails? I can get both cfls to come on may be 1 time out of 4-5 tries. Get a lot of flickering.
Help me?
__________________
Noob
Poor noob who want some lights.
  #2
Old 03-03-2007, 09:17 PM
gadget_lover's Avatar
gadget_lover gadget_lover is online now
*Flashaholic*
Default Re: Serial connection : 2 shop lights and a switch.
The switch goes in series, but the shop lights are in parallel with each other.
You are lucky to get anything to light, since they are running at 1/2 voltage.
Daniel
__________________
I have got to plan my procrastination better!
  #3
Old 03-03-2007, 09:19 PM
DUQ's Avatar
DUQ DUQ is offline
Are you going fixture to fixture or feeding each fixture seperately?
__________________
  #4
Old 03-04-2007, 04:30 PM
HEY HEY ITS HENDO's Avatar
HEY HEY ITS HENDO HEY HEY ITS HENDO is online now
are the fittings new?
did you test them before installing them?
you need to supply each fitting with a neutral from the fuse box, i.e. one wire to the first fitting then a link wire into the second fitting,
and a switched live from the wall switch to the first fitting and a link wire into the second fitting
............ let us know the outcome
__________________
  #5
Old 03-07-2007, 04:22 PM
Newuser01's Avatar
This represent what you are saying, right?
I think I did that right, But double check. Hmm, wonder what else might be......
__________________
Noob
  #6
Old 03-07-2007, 07:20 PM
brickbat brickbat is offline
yeah, that'll work. You might try a Google on the words series, parallel, and circuits...
__________________
Jim
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
