CandlePowerForums
Go Back   CandlePowerForums > Administrative > Practice Posting
CPF Only
User Name
Password
Register
Advertising on CPF!
Closed Thread
Thread Tools Display Modes
  #1
Old 11-17-2002, 12:21 PM
eTech
Guest
Posts: n/a
Default Glow Powder Nightlight
Hi,
I have been following CPF for almost a year now. I finally decided to register. Anyway the reason for this post is that I had this great idea for a nightlight for my bathroom. It seemed that the new type of glow powder that is available it could be used to provide usable light for several hours after the fluorescent light is turned off. Unfortunately this didn’t work.
I used a plastic Taco Bell cup and cut a hole it the bottom of it. I also cut the top off to the same height as the spiral fluorescent bulb that I already had in place. I mixed 1/2 ounce of glow powder with 0.45 ounces of clear fingernail polish. I then painted the inside of the cup with the paint. After installing the cup on the spiral fluorescent bulb through the bottom of the cup into the socket I gave it a try.
I let it charge for about an hour then turned off the light. It glowed with sufficient brightness for about 3 minutes and then it dimmed dramatically. Even then it was still barely bright enough to be useful. But that only lasted for about an hour.
Any ideas as to why it didn't do a better job? I purchased the aqua glow power from ReadySetGlo.com
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
