CandlePowerForums
CPF Only
User Name
Password
Register
4Sevens
Reply
Thread Tools Display Modes
  #1
Old 03-16-2007, 02:51 PM
kennyj's Avatar
kennyj kennyj is offline
Default Purple SMD LEDs?
I have a side project where I'm buying broken Sansa e200 MP3 players from eBay and repairing them. It's working out well, but I want to personalize these a bit; leave my mark as it were. They all have click wheels that light up during use; these wheels are made of translucent white plastic. The light comes from four small SMD LEDs, and the only color offered is blue.
I want to do something unique and make it purple instead. I still haven't identified exactly what size or spec the LEDs are, but others have had success transplanting red LEDs salvaged from other devices.
Only problem is, I can't seem to find consumer-market purple SMDs. Anyone know of a decent source for these in smaller quantities? At most I might get 40-50 of them, but first I'll want a small sample just to see how they look.
  #2
Old 03-16-2007, 05:12 PM
brickbat brickbat is offline
Default Re: Purple SMD LEDs?
I've not seen purple LEDs either. Two options - use a white LED with a purple filter, or get a bicolor red/blue LED and set it up for a nice magenta. Or since there are 4 LEDs use 2 red and two blue.
__________________
Jim
  #3
Old 03-16-2007, 05:50 PM
Nitroz's Avatar
Nitroz Nitroz is offline
I have quite a few small red LEDs if you're interested.
__________________
My Collection
18650 Cree light Surefire KL1R Gladius K2T
  #4
Old 03-16-2007, 05:57 PM
kennyj's Avatar
I've seen purple LEDs but not SMD... Granted there aren't many of them either.
I guess I might be able to pull off a 3mm LED if I sand it down a bit and mount it at an angle, but it's a *really* tight fit.
  #5
Old 03-24-2007, 07:38 PM
LumenHound's Avatar
LumenHound LumenHound is offline
Would something like these size 1206 UV SMD's work or do they have to be 410-415nm?
  #6
Old 03-25-2007, 03:53 AM
liveforphysics liveforphysics is offline
The purple SMD LED's I used to work with doing cellphone mods years ago were a red LED paired right next to a purple LED, and covered by a cloudy white diffuser. The red of course had a tiny resistor built in to prevent it from burning up when the package received the 3.6V that the blue LED next to it needed to light.
Pretty slick little units, definately had a purple look to the light, and definately were the most difficult of all the SMD LED packages to solder, as temperature caused the 2 LED's to unbond from eachother very easily if you hesitated for more than a moment during the soldering.
  #7
Old 03-25-2007, 01:59 PM
2xTrinity's Avatar
2xTrinity 2xTrinity is offline
Quote:
He wants an LED that looks purple, not one meant for lighting up fluorescent paints (checking money etc) -- which means that red + blue is what he's looking for, and will be a lot more efficient than spectral violet/UV (the eye is not very sensitive here).
  #8
Old 03-26-2007, 01:40 AM
kennyj's Avatar
Where did you get those little LED combo packages from?
  #9
Old 03-26-2007, 02:12 AM
Tronic Tronic is offline
lc-led.com have purple SMD LED but they are not in stock.
Maybe you can mix the color with this RGB fullcolor LED
Or you can try a pink LED.
http://www.led-shop24.de/pd846703482.htm?categoryId=51
http://www.dotlight.de/shop/product_...roducts_id/415
(I don't know if this shop ship to US but I can forward the package for you)
  #10
Old 03-26-2007, 11:08 PM
Mark_Larson Mark_Larson is offline
I have one of the players you are talking about, and I think white would be cooler.
  #11
Old 03-28-2007, 01:49 AM
kennyj's Avatar
http://www.anythingbutipod.com/forum...splay.php?f=50 Two of the stickied topics are LED mods - one is just darkening the blue LEDs, the other is a red LED replacement.
I don't think plain white would be all that great personally, but there IS the point that it can be filtered to produce a more desirable color...
Tronic, thanks for the links, and thank you very much for the offer. I'm not in a hurry to buy the parts at the moment, but I'll keep an eye on that stuff and if I need, I'll get back to you with a PM.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
