CandlePowerForums
CPF Only
User Name
Password
Register
illuminationgear.com
Reply
Thread Tools Display Modes
  #1
Old 03-25-2007, 03:25 PM
GalvanickLucifer GalvanickLucifer is offline
Default What is the better UV wavelength to detect cat pee?
The wife wants a black light to look for indications our cat has been spraying. Could get an el-cheapo "Stink Finder" or use it as an excuse to buy another flashlight. A quick search turns up one Inova and 2 Streamlights - a 390 nm light and a more expensive 375 nm light. Is the shorter wavelength light better for detecting cat urine or does it really make any difference?
__________________
"For a moment, Waterhouse thinks that one wall of the building has collapsed,
exposing them to the direct light of the sun. But Ghnxh has simply turned on the galvanick lucipher ..."
  #2
Old 03-25-2007, 03:27 PM
2xTrinity's Avatar
2xTrinity 2xTrinity is offline
Default Re: What is the better UV wavelength to detect cat pee?
The 375nm will be much better -- shorter wavelengths tend to cause things such as biological fluids to fluoresce. 390nm is actually still largely within the visible range, so will throw a lot of visible violet light, which will make the fluorescence harder to see, and in general won't be as effective.
  #3
Old 03-25-2007, 05:53 PM
Trashman's Avatar
Trashman Trashman is offline
Yep, the shorter wavelength will be better.
These ones will work very well:
http://cgi.ebay.com/Pet-Urine-Stain-...QQcmdZViewItem
http://cgi.ebay.com/380-385-nM-UV-Ul...QQcmdZViewItem
I bought the second one,--the 21 LED 380-385nm UV flashlight--from this same seller. It really works well. I have/had some other UV flashlights with a higher wavelength, and this Chinese one blows them away. Don't buy the 9LED 380-385nm unit (also sold by the same seller), as there have been reports that it stinks compared to the Teralux UV Minimag upgrade, which is one of the lights that I'm saying stinks compared to this 21 LED model. I expect that the top link, the 38 LED model will work even better. I've bought a few things from this seller. Once, the item didn't work when received, and it was was replaced by the seller. If you buy from him, it might be wise to request that he checks the unit before shipping, even if he has to remove it from any packaging it might have.
  #4
Old 03-25-2007, 05:54 PM
Lighthouse one's Avatar
Lighthouse one Lighthouse one is offline
Lighthound has a $7.00 uv light....that should do it ( what happened to her nose? )
__________________
(Milky Mod) Striker VG, SL Scorpion Led, Huntlight FT01 and FT-02XJ, Wolf Eyes 9 v Raider and 3.7 v sniper, Ledbeam 3 watt, Goncz E-3, D-Mini Lumapower, Eastward YJ Cree, Drumlights, Surefire G2, Dereelight ,Ultrafire 500, Power on Board HID, Olight T 20 Q 5, Zebralight H-30, Nitecore EX 10, Eagletac T10C2, MTE P 7D
  #5
Old 03-25-2007, 07:03 PM
Lobo Lobo is offline
I have the lighthound UV.
http://www.candlepowerforums.com/vb/...ght=lighthound
I wouldnt recommend it for identifying, ehm, bodily fluids. That, or I'm much cleanlier than I thought.
  #6
Old 03-26-2007, 10:16 AM
Cydonia's Avatar
Cydonia Cydonia is offline
What about those Photon I Micro-Lights in UV? 370nm 1 LED.
http://www.batteryjunction.com/phimiulviled.html
and this one too:
http://www.batteryjunction.com/phfrmiulfm.html
  #7
Old 03-27-2007, 07:07 PM
Quote:
Thanks for the info!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
