Quote:
Originally Posted by lpcmidst128
I've never seen traffic lights change from red to green when emergency vehicles approach. So its likely not very widely used yet. I'm guessing its has to be some special remote transmitter on the emergency vehicles and the traffic signals have the receiver.
I believe some transit buses have something that holds the green light (opticom?). So when they accelerate from a bus stop they don't have to suddenly stop.
I have seen them in action before. Here is a better explanation of how they work:
Explanation of Traffic Signal Preemption
The normal operation of any traffic signal controlled intersection is designed for the maximum and efficient throughput of vehicular traffic.
Unfortunately, a common occurrence at any intersection is traffic back-up, which can require many signaling cycles to clear. Without the ability to change the operation of the traffic signals themselves, police and emergency response vehicles can also be forced to sit in traffic, thus dramatically increasing their response times to crime scenes and fire or medical emergencies.
Furthermore, even without heavy traffic, a police or emergency response vehicle entering a traffic signal controlled intersection at a high rate of speed places all motorists (and sometimes pedestrians) at extreme risk.
Traffic signal preemption is an optical communications system that allows preemption-equipped vehicles to alter the normal operation of preemption-equipped traffic signals.
An overview of a typical scenario is as follows:
A fire truck is dispatched to an emergency.
The fire truck is equipped with multiple emergency warning lights and a siren… The fire truck is also equipped with a preemption transmitter, which, in operation, is a high intensity forward-facing strobe light that is flashing at a rapid rate - much faster than normal attention-getting lights on the fire truck.
When the fire truck approaches within 1,800 feet (line-of-sight) of a preemption-equipped traffic signal controlled intersection, the preemption detector (normally mounted on the cross-arm that suspends the traffic signal) "sees" the fire truck’s preemption transmitter and locks onto its flashing strobe.
Once the traffic signal "sees" the fire truck, it begins to initiate a "preemption sequence" of the actual traffic signal that is different from normal operation.
If the fire truck already has a green light, the light will remain green. Any other direction that also has a green light (usually the opposite direction) will first get a yellow light, then red.
When all of the other directions are then red, and the fire truck’s direction is the only one that is green, the left turn arrow will illuminate (if one exists), and a brilliant white flood lamp mounted near the traffic signal will begin to flash. This flood lamp tells the driver of the fire truck that he now has control of the intersection, and complete right-of-way.
If the fire truck has a red light, any other direction that has a green light will transition to yellow, then red. When all the directions (including the fire truck’s) are red, the traffic signal facing the fire truck will then turn green, along with the left turn arrow (if one exists), and the brilliant white flood lamp will begin to flash.
Once the fire truck has passed through the intersection, optical communication with the preemption detector (on the traffic signal) is lost. At that time the traffic signal will default back to normal operation. Conversely, until the fire truck passes through the intersection, it will have a green light, regardless of the time duration.
If several intersections are within the 1,800 foot range of the fire truck’s preemption transmitter, they will all respond accordingly to the above operational description.
Copyright ©2003 Beeco Sales, Inc.
Site Development by The High Bridge Design Group
