04-08-2007, 12:42 PM
washing a building with blue light ?
I've recently been asked if i knew a good way to wash the front of building with blue light.
the building is 30' high and is clearly visible from the 401 (trans Canada hi way)
are there colored HID bulbs out there? anything else?
Umm...help?
__________________
04-08-2007, 07:26 PM
Re: washing a building with blue light ?
Quote:
Originally Posted by red_robby
...are there colored HID bulbs out there? ...
Yes, Check Venture:
http://www.venturelighting.com/Lamps...gnercolor.html
__________________
Jim
04-08-2007, 09:50 PM
thanks for the link.
looks like I'll have to give them a call
__________________
04-08-2007, 10:38 PM
This should be fund to watch develop. It'll certainly attract mosquitos and moths; the whirly cloud of little blue-lit dots flying around the building will be a signt to behold. And it should get a lot of hits during bird migration, if it's on a flyway. Not to mention the effects on people: http://www.health24.co.za/news/Depre...-903,24791.asp
04-09-2007, 12:42 PM
Quote:
well...it's aupposed to attract attention to the building so I guess I'm on the right track.
__________________
04-09-2007, 04:57 PM
I've been useing SGM Palco LED wash lights on buildings recently for temporary installations, they'd make great permenant lights too. They're actually "full" colour so you could have a bit of fun at times too!
__________________
We cannot hold a torch to light another's path without brightening our own.(Ben Sweetland)
04-09-2007, 09:58 PM
Yeah. It used to be that they listed 'standard' colored MH lamps on their site. Seems like they offered blue, aqua, green, pink, maybe others... They offered them in the largish sizes - around 250W or so.
If you're serious, I'd suggest you post your question on sci.engr.lighting. Some of the guys there work in the lighting industry and might have some ideas.
__________________
Jim
04-10-2007, 06:02 AM
Quote:
I guess this might sound like a joke but it isn't...
I've already ordered 4 bulbs through my supplier, I'll post pictures when I'm done
thanks again for the help.
__________________
04-19-2007, 06:27 AM
Mercury vapour lamps covered with lighting gel of your choice.
Will be the cheapest, and most effective way.
04-20-2007, 04:42 PM
While the mercurty option is probably cheaper up front, power consumption will be a lot higher using a filtered mercury vapor lamp than using a metal halide that is designed to emit blue light (by using blue-emitting fill gases), using the colored metal halide lamp is probably most cost effective long-term, though a lot of that may depend on local cost of electricity.
04-21-2007, 08:04 AM
You're right.
For some reason I read this as a temporary thing.
Now that I re-read the post, it does sound like they want a permanent solution.
For a long term set-up, the gels will fade also.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
