CandlePowerForums
CPF Only
User Name
Password
Register
FoxFury Fire Helmet & Hard Hat Lights!
Reply
Thread Tools Display Modes
  #1
Old 04-24-2007, 12:12 PM
Corona Corona is offline
Default LED strobe light project
I'm currently designing and building an LED based strobe light for the amusement of my 10-year old. A chip off the old block
I've built a number of Xenon flash tube based strobes (back in the 70's and 80's) and wanted something a bit safer (400V inside and line powered = nasty). I will never forget getting whacked by the 6kV trigger pulse during testing. And the UV output of a xenon tube is another reason to go with LEDs.
My plan so far is to use a 5500K LED (a little bluish is somewhat xenon-like). I have a few Lite-on LOPL-E031W emitters on hand (3W, 75 lumens @ 700mA). I'm driving it with a PIC-based pulse generator of my own design. The PIC reads a pot to change the pulse rate, and drives a logic-level FET to switch the LED. The whole thing is powered from 5V (yep, lots safer than Xenon!).
Since the duty cycle is VERY short (about 100uS ~ 500uS on time), I'm going to drive the LED at 2-3 amps peak current. Expect to get >150 lumens out of it.
If it works out as well as expected, I'm going to design a more useful, calibrated version with a digital encoder and LCD display - a stroboscope - for RPM measurements, guitar tuning, whatever.
Anyone else ever made such a thing and/or have any interest in a DIY project?
  #2
Old 04-27-2007, 12:55 PM
Clayton Bradley Clayton Bradley is offline
Unenlightened
Default Re: LED strobe light project
Not sure what kind of help you're looking for, but I just wanted to chime in with my project. Sounds very similar.
PIC controlled LED flasher. Mine flashes at about 30uS, or depending on the pattern chosen via a momentary push button. 5v for the chip, 12v (used by 4 series of 3 superflux blue) for the LEDs. I am use NPN transistors for controlling the current to the 4 series of LEDs. This allows individual control of each series for the purpose of differing flash patterns.
Currently I am looking into reflectors/focusers for this light.
As to your higher plans, here are a couple of websites you may not have, or if you do, Im sure you agree they are worth a repost.
http://www.winpicprog.co.uk/pic_tutorial.htm (lots of high end stuff here, in assembler)
Here is another great site for PIC projects, a lot of knowledgeable folks:
http://www.electro-tech-online.com/
Clayton
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
